Exhaust question
Bradderz_1988 Mar 11, 2013
  1. Bradderz_1988
    3,926
    231
    As i will be getting my hands on a full milltek system at some point this month i want to now the diameter of the standard TQS exhaust system as i need to order some new clamps for the downpipe and the back box ??
    i think i asked this question a while ago but i cant seem to find it is it 2.25" ????
  2. aragorn
    17,960
    702
    stock system is 2.25" or 57mm
    If your fitting a milltek system its larger afaik?
  3. PaulJC84
    PaulJC84 Owner
    2,890
    13
    I am sure I read the miltek is 2.75"
  4. Bradderz_1988
    3,926
    231
    Ye the milltek is 2.75 but im gunna order some for my system do that when i do the swap there will be all new clamps and gaskets on the car the milltek is coming off.
  5. aragorn
    17,960
    702
    ah k
    The stock system is one piece, so you should only need the clamp at the downpipe unless the backbox has been replaced at some point.
  6. Bradderz_1988
    3,926
    231
    Theres a clamp at the rear so suspect its been replaced at some point.
  7. aragorn
    17,960
    702
    best measure it, ETKA says some systems are 55mm and some are 60mm at the joint between boxes...
  8. Bradderz_1988
    3,926
    231
    I might aswel just order both size clamps and just have parts at work send the wrong one back rather than going under the car !!
