Exhaust on a 2000 2.8 Quattro
scammo Oct 14, 2011
  1. scammo
    scammo New Member
    9
    Does anyone know if the exhaust on this car is one piece from the cats back?
    I need to change the centre silencer only but was told that the whole system is one part (£360!)
  2. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,741
    165
    I have a 98 2.8 and the exhaust from the cats is in one piece. I'm not sure if this has been welded or not as I was also under the assumption that the rear silencer and middle silencer split. But maybe its not the case??
  3. aragorn
    18,577
    868
    Audi sell the system as two parts, and supply a joiner. The stock system is one piece though.
    That said, the centre box alone is ~400 from Audi.
  4. jamie226bhp
    jamie226bhp Member
    468
    I've got an rs4 centre silencer you could have but you'd need to make it fit ax I cut the rear bix off for mine but I'm based in dartford or remove it and put a straight through pipe in instead
  5. S4_dan
    2,741
    165
    That will explain my one piece the and its condition then. 170K, 13yrs old and only a bit of corrosion on the middle box! The rest of the system is in very good condition!
  6. Nitro
    Nitro Member
    183
    I have a 2,8 Q year 2000 w reg, took off the original standard exhaust, it was two piece from the cats back & fitted a Miltek 3" system which was a Three piece system - 1st) the two into one section (from the two Cats to the one 3" pipe) 2nd) the center box - 3rd) the rear box.
