Exhaust metallic resonance/drone
AL_B May 24, 2006
  1. AL_B
    AL_B Well-Known Member Team Daytona Audi S3 DSG
    1,755
    202
    All,
    Since the gear-box has been put back in my car, the car now has a metallic resonance/resonating/buzzing sound on over-run...at exactly 3400rpm, as the revs fall. Car needs to be warm, and in 2nd or 3rd gear for the sound to be prominant. It also seems to be louder when cornering left, but never occurs when cornering right.
    It sounds to me like its the exhaust or a heat shield or something!
    I don't think it is gearbox related, as gear changes are fine, no vibrations through the gear stick.
    Any ideas?
    AL
  2. RichA3Turbo
    5,089
    Check the heatshields for the exhaust from downpipe all the way back... dont necessarily follow your ears as they can mis-guide you!
    Have a look around everywhere that would have been disturbed for the 'box to come out/
    Rich
  3. AL_B
    1,755
    202
    Cheers Rich
    Hopefully the weather will hold off for the weekend.
    AL
  4. RichA3Turbo
    5,089
    Don't hold your breath! Mind you, might need to if it keeps raining!! /ubbthreads/images/graemlins/crazy.gif
  5. S3_MCD
    S3_MCD Member
    389
    Agree - heatshield .... happened to mine. A bit of 2"x1" is good to push and reshape it out of the way.
  6. ollyste
    ollyste Member
    72
    AL l have the same metallic sound on mine but at about 2400rpm.I believe its ok to to remove the heatshield and this hopefully will solve the problem.
    Does anyone know if this is correct?
  7. darko
    darko Member
    272
    probably best not to remove a heat shield on turbo cars as the exhausts run so hot - i had a lot of problems with one integrale before and it turned out someone had removed a heat shield, the knock on effects were a nightmare !
  8. ollyste
    ollyste Member
    72
    what kind of knock on effects Darko id be interested to hear /ubbthreads/images/graemlins/smirk.gif
  9. darko
    darko Member
    272
    from memory (which is a bit hazy these days..) 2 electrical sensors expired early causing over fuelling (which was luckily caught early) a rubber oil return pipe went brittle and cracked due to being blasted by heat (the integrale turbo regularly was glowing bringht orange !) it also caused a hand brake cable to seize which was how we found the problem as we kept replacing them. there were a few other problems which, although never directly could be linked to the gaurd missing could easily have been caused by excessive heat
  10. AL_B
    1,755
    202
    Thanks for the suggestions.
    I didn't get round to checking the car, had to do the garden instead - shifting a ton of gravel by just buckets.
    I'm sure this has been asked before...whats the best place put the axle stands?...Don't want to damage anything.
    S3_MCD,
    Which heat shield was it for you?
    AL
