Exhaust manifold bolts coming loose on 2001 S3
viper6 Jul 22, 2009
  1. viper6
    viper6 New Member
    Hi all
    i a newbie S3 owner
    had the car about 1 month and loving it!
    one thing i want to ask is
    the exhaust manifold bolts come loose
    every now and then
    just wanted to know if there is a fix and if this is a common S3 problem
    cheer's
    Viper6
  2. viper6
    viper6 New Member
    it's a late 2000 model with 74k apy Engine
  3. Andrew@A.L.D
    3,879
    617
  4. viper6
    viper6 New Member
    Manifold to head Bolts
    maybe i should of mentioned this at the start:blush:
    cheer's
    viper6
  5. Andrew@A.L.D
    3,879
    617
    I had the same problem but with the Turbo to the manifold and it ended up been the dog bone bush had gone thus making the engine move more putting stress on the manifold
    Have a look at the mount, it could be that?
  6. Broken Byzan
    13,244
    468
    Does it cause blowing? or are you just wrenching periodicaly to check them
  7. ianysm
    ianysm Active Member
    1,002
    Never heard of it. Maybe an older model problem?
  8. golf
    golf ***** rent boy VCDS Map User
    1,556
    I was also wondering about this!
    My manifold is loose and makes a rather embarrassing blowing noise. When I went to inspect it I found one of the bolts to be missing so I bought a new one (£6.80 from Audi [​IMG]) thinking it would sort out the problem.
    It didn't.
  9. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    Lock tight?
  10. Andrew@A.L.D
    3,879
    617
    Wouldn't the heat from the manifold/Turbo burn it off?
  11. viper6
    viper6 New Member
    Thanks for the info Chap's
    The bolts just seem to work there way loose
    then i need to take of the charge pipe and access the bolts
    and re-tighten.
    the dog bone bush is it visable from the top side of the engine?
