Exhaust manifold blowing
willh92 Dec 11, 2013
  1. willh92
    willh92 Active Member Audi S1 Team Brilliant Black
    335
    49
    I can see smoke coming from the back of the engine, it seems to be coming out from one of the bolts holding the exhaust manifold on to the head. It's hot and does smell like exhaust fumes so i'm fairly sure it is the manifold leaking past the gasket / cracked. Just wondering if anyone has had this problem and what costs are likely to be incurred?Also, could this cause a rough idle and / or cutting out upon start up when the engine is already hot? Cheers Will
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Fairly common, usually a bolt works loose then blows the gasket, can cause all you have mentioned..
    If unlucky a cracked mani, is it standard?
  3. willh92
    335
    49
    Right, so what would you suggest I do, take it to Audi and pay an arm and a leg but have peace of mind (have a good relationship with my audi garage). Or source a second hand mani with replacement gaskets / bolts and try do it myself?Yes it is standard, covered 79,000 miles.
  4. s3dave
    10,110
    736
    You need to know what the problem is first, loose bolt or cracked mani.. take the charge pipe off and have a look..
  5. willh92
    335
    49
    might be a stupid question but what's the charge pipe, the big silver pipe from turbo to inlet mani?
  6. s3dave
    10,110
    736
    Yes mate.. just gives a bit better access to look /feel..
  7. willh92
    335
    49
    Ok cheers for your help mate I'll check it all out at the weekend !
