Exhaust help needed ?
alistair666 Nov 21, 2009
  1. alistair666
    alistair666 Member
    80
    needing to replace my knackerd exhaust i have sourced a milltek downpipe and a jetex cat back stainless system
    this pic shows the downpipe on the left to jetex center. was expecting the jetex to fit over the downpipe after seeing the slits in the pipe but when fixing together the jetex fits snugly inside of the downpipe
    will this be ok to fit this way and will i need to cut some slits into the downpipe to make it close up over the center section
    cheers
  2. ben_turbo1
    ben_turbo1 Member
    181
    Not sure if I totally understand what you have got but shouldnt there be the cats between the down pipe and cat back exhaust? If not and those two pieces do need to go together then you will need to make some slots in the outer pipe so that it will clamp down onto the inner piece.
  3. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Or weld it.
  4. alistair666
    alistair666 Member
    80
    sorry ben
    on the left is the 3" milltek downpipe which has the sports cat and on the right is the jetex center section
  5. Keeno
    Keeno Spooly Spooly Boosty Boosty!
    701
    Weld it. Last a lifetime then!
  6. zeeeebo
    zeeeebo Lifes one big laugh
    416
    exhaust sleeve off ebay did the trick on mine:)
  7. ben_turbo1
    ben_turbo1 Member
    181
    Personally I wouldn't weld it as exhaust joints like this one are very handy for adjusting the system fitment. As suggested buy a sleeve or cut some slots in the outer pipe but make sure they are not parallel as the gasses will leak out. Where in the country are you? I may have a sleeve somewhere.
  8. alistair666
    alistair666 Member
    80
    cheers guys exhaust fitted yesterday after an afternoons work
    happy with the fitment but not the noise, i thought jetex was the quiet performer
    it sounds very deep and boomy and and tends to drone could this be the 3" milltek downpipe ?
    im not adverse to loud exhausts owned a scooby with a magnex and an evo with a super dragger but this just sounds too deep
    any sugestions ?:think:
  9. alistair666
    alistair666 Member
    80
    id like to keep the miltek downpipe after seeing how restrictive the original was
    so i think options are either find a quieter catback system / backbox or to fit the old genuine system to the miltek downpipe
    any ideas
  10. alistair666
    alistair666 Member
    80
    anyone ?
  11. alistair666
    alistair666 Member
    80
    Would anyone advise fitting a 3" downpipe with a standard center and backbox?
