exhaust fumes smell very rich possible cause ?
bigblokey0 Mar 25, 2007
  1. bigblokey0
    bigblokey0 Member
    745
    as above
  2. marmite
    marmite Counting the Tesco Club points
    1,101
    How is the car running?? Performace etc?
    Have you changed your fuel supplier?
  3. bigblokey0
    bigblokey0 Member
    745
    car seems to be running fine however petrol consumption has gone up a bit ive not changed fuel suppliers
  4. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    When are you smelling this, while on the move or when stationary?
    When was the last time you had a service?
  5. dummi
    dummi smoking a6
    1,210
    could be a leak in the petrol tank??
  6. bigblokey0
    bigblokey0 Member
    745
    i only smelt it this morning when it was idleing might just be because it was first thing this morning
  7. TonyT
    TonyT Finally got my A6
    85
    if fuel consumption has gone up it is possibly the engine temp sensor. keep an eye on your fuel bills. My local audi garage explained the engine temp sensors can fail (only about £12 and they had ten in stock). This fools the ecu into thinking the car is colder than it actually is and drops a bit more fuel in, on a bit of choke as it were. eventually it will cause rough running, not sure what else
    or it might be nothing :think:
    TonyT
  8. bigblokey0
    bigblokey0 Member
    745
    where are the engine temp sensors located ?
  9. TonyT
    85
  10. vw754
    vw754 vorsprung Durch Technik
    2,331
    58
    what car/model??????????
    IVE GOT SAME SYMPTOMS!!!!,except mine takes around 3-4 seconds to fire/start up,instaed of the usual 1 second.
    Ive changed temp sensor,about 2 -3 months ago(noticed no difference) still strong smell smell and heavy on fuel,mainly localy.:wtf:
    A4 TDI 130. (B6)
  11. bigblokey0
    bigblokey0 Member
    745
  12. bigblokey0
    bigblokey0 Member
    745
    im on about the 1.8 turbo petrol
