exhaust drone a 2000 revs - 1.9 tdi
technics100 Feb 16, 2006
  1. technics100
    technics100 Active Member
    850
    25
    I'm getting a drone from my exhaust from 1800 - 2000 rpm. its only there and in every gear. anyone else ever get this? At first i thought it was a loose heat sheild or similar, but now definately sounds like exhaust drone...
  2. Lynas
    Lynas Member
    99
    Hole somewhere, or something other than heatshield vibrating off something else?
    Loose exhaust rubber somewhere?
  3. clough103
    clough103 Member
    76
    i hope someone can come up with a fix as mine is doing it too. tried allsorts
  4. murran
    murran Well-Known Member
    1,545
    39
    does the exhaust shake excessivly on tickover? the flexible part of the frontpipe can start to seize up causing this and the droning your on about.....
  5. clough103
    clough103 Member
    76
    will check that out tomorrow and report back
  6. deanski
    deanski wax on, wax off
    369
    there's a couple of threads about this and I thought it was my injectors! but it now seems the sound is coming from the back. it tend to stop after the car gets very warm?
  7. paul20v
    paul20v Audi fanatic
    1,113
    What flexi part of the front pipe
    there isnt one .
  8. chrisash32
    chrisash32 Member
    573
    yes, this is likely to be the case. It was mentioned on my MOT and i get the same noise at the same RPM.
    To find it, look under the bonnet just behind your turbo. you will see the down pipe going to the exhaust will a flexible bit of pipe. This is the bit that is going on mine.
  9. swarcup
    swarcup Well-Known Member
    1,326
    40
    have you changed your tyres? these can drone at certain road speeds. Just a thought
  10. simon.m
    simon.m Active Member
    2,747
    think he means the wier mesh looking bit where it comes up to the turbo mate
