Excessive play in rear bearing
TeKnodriver Jan 16, 2014
  1. TeKnodriver
    TeKnodriver Biodiesel Purrrr
    166
    MOT fail for excessive play in rear bearing.
    new bearings discs and pads went on about 10,000 miles ago
    is it just a case of tightening (as described in Haynes, new split pin and grease)?
    could wheel alignment being out cause bearing to need this adjustment?
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,705
    643
    No, mostly likely someone has just not tightened the nut up enough or it somehow come lose. You can reuse the the split pin and grease, if you got the Haynes instructions then it's a very simple fix.
  3. TeKnodriver
    166
    well, 20 minute lunchtime fix...
    nut was loose, washer behind it rattled around.
    have tightened it to remove play and washer is free to slide - just!
    no chance of re-using the split pin as it was too bent but had one in toolbox
    hoping this is not over-tight because the bearing has worn too much.
