excessive oil consumtion? Or is it?
riggssuzuki Oct 31, 2012
  1. riggssuzuki
    riggssuzuki Active Member
    496
    57
    My 10000 mile 2.0 TFSi seems to have a thirst for its high quality fully synthetic oil. I seem to be topping up 1 litre per every month and a half. Is this normal? There are no leaks and there is no burning of oil as far as we can ascertain. Exhaust seems fine i.e. no blueish smoke etc.
  2. Artimus
    Artimus Shortback
    2,005
    476
  3. ScottishA4B9
    ScottishA4B9 Well-Known Member Team Daytona Audi A4 S-line owners group TDi saloon
    2,975
    759
    Well after popping into Highland Audi to see about mu HUGH oil consumption, it turns out that Audi are aware of a problem with the engine and they recommend that there is crankshaft seals & sensors that can be changed and a software update to resolve the problem. There has been no recall for this therefore it would be up to the owner to pay the £260 to have it done.
  4. Hesl
    Hesl Member
    43
  5. ScottishA4B9
    2,975
    759
    I tried Audi Customer Services as well but it looks like owners have to pay for the modification
  6. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
    Same with mine, i shouldn't really worry, im up to 14000 and it is using less now, it does say somewhere in the handbook that the 2.0 Tfsi uses more oil than usual.
  7. ScottishA4B9
    2,975
    759
    Well I have had the crankshaft seals replaced and had a software update and it seems (so far!) to have fixed the problem of excessive oil consumption. Audi know about these faults and have put out recommendations for the 2.0TFSI engines.
  8. Audi Dynamik
    2,218
    308
    A Software update and a Revo Remap doesn't mix :L mines fine anyway.
  9. Mcdubber1
    Mcdubber1 Member
    255
    Mine uses quite a bit but again mine is remapped so the software update may wipe that. Audi should be recalling all cars and paying for the fix be wise it is clearly a fault with the car.
    Maybe if we contact Audi UK direct and see what they say? Why should the US market get it for free and not us?
  10. ScottishA4B9
    2,975
    759
    I spoke to Audi UK but they stated that only issues affecting vehicle safety are given re-calls hence there isn't one for the Excessive Oil problems. They have got a warning marker on the Audi system for it, but will not inform customers until a problem is reported to them.
  11. riggssuzuki
    496
    57
    I have contacted Audi UK and await their formal reply.
  12. riggssuzuki
    496
    57
    Update.
    Audi have stated:
    'Our technical team have advised that weare unaware of any known issues in regards to oil consumption for your model;however they have advised that the maximum tolerances are ½ litre every 1,000km (620 miles approx).'
    Hmm. Unifnormed ir really theres not actually an issue. 1/2l per 620 miles seems a bit excessive to me.
    Answers on a postcard please.
  13. Mcdubber1
    Mcdubber1 Member
    255
    How can they possibly think using half a litre of oil every 620 miles is acceptable? Sounds like they make the tolerances up to suit themselves.
    Maybe a recall isn't required but them to pay for the fix is imo.
    There was a similair thing when I owned my Leon FR Tdi witht the injectors. They were failing on a lot of cars (not mine) and it was a known problem by Seat but owners were still having to pay for new injectors to be fitted, it was over £2000 for all four and the loom. Long story short complaints were lodged by owners to Seat UK and also VOSA and a recall was eventually done but it did take a long time, well over a year if i remember correctly. That was a safety issue though because cars were just cutting out suddenly without any warning so something like this may be a bit more difficult to turn into a recall. I really don't fancy paying for it though.
    I've not told my dealer about it yet. Do you think I should go to them first or just go right onto Audi UK? My car goes in on the 20th to get new wings (corrosion) so I'll probably speak to them then about it.
  14. fsures
    fsures New Member
    22
    Audizine.com has extensive coverage on this issue in the States. Audi replace pistons & rings on my 2009 with 45,000 miles on the motor.
  15. riggssuzuki
    496
    57
    Any links etc you can send would be greatly appreciated. I dont plan to let this one go. I am sick of the 'we dont know about any issues' from dealers. I had the same on my BMW in ref. to Inlet swirl valves. BMW said they didnt know of any issue yet when they called the part up on their pc they were out of stock and hundreds had been ordered in the past hence they must have been replacing something for some reason!!!!!!!! Bloody dealers!!!
  16. ScottishA4B9
    2,975
    759
    I know what you mean about dealers denying they know theres a problem. I had massive issues with BMW when my ecu went bang on my E90 3 Series. They wanted £1500 for a new one and I argued the case and they eventually admitted it was a common fault and paid the repair costs. It still put me off BMW.
    I initially found out from my local dealer that there was a known issue with the oil consumption on the 2.0TFSI. When I spoke to Audi UK they didnt admit it initially but in the end they did but stated it wasn't part of a re-call as it wasn't a safety issue.
  17. fsures
    fsures New Member
    22
  18. ScottishA4B9
    2,975
    759
    Well it looks like the last work on my car to try and fix this problem didn't work. Just done 350 miles and its used 2 litres of oil!!!!! It's beyond a joke now. I put in more oil than petrol! No oil leaks so don't know what's going on! Out if interest, did you ever get a reply from Audi Kev?
  19. Mcdubber1
    Mcdubber1 Member
    255
    Mine is in at the moment getting new wings and after that is done the first phase of the oil consumption test will be carried out. I was told that if they think that it is excessive then it will require new pistons and rings. No mention of oil seals or anything else. Something else that wasn't mentioned was who would pay for these new pistons and rings!
  20. ScottishA4B9
    2,975
    759
    I've already had the crank shaft seals and sensors replaced as well as a software update as that's the first fix Audi do for excessive oil consumption and then you have to monitor it for 1000km. I really hope it's not pistons etc that need replaced next as that sounds bloody expensive! I got the first work done by Audi as a good will gesture but I had to pay the £230 labour charge. They need my car for 4 days to carry out the work and for testing. Incidentally I had to contact Audi UK and argue the case for the good will gesture. It baffles me that Audi know about this problem and Audi America fix it for free but Audi UK don't do it as a matter of course.
  21. ScottishA4B9
    2,975
    759
    let me know how you get on mate.
  22. ScottishA4B9
    2,975
    759
    I don't know if I trust that MMI oil level actually. I don't know if its even possible to do it manually?
  23. Mcdubber1
    Mcdubber1 Member
    255
    Still not got my car back again but pick it up on Monday, that'll be 2 and a half weeks they've had it!!! From there we'll see how much oil it uses in the 1000km, enough for them to sort it hopefully. I only hope they've done a good job on the wings.
  24. SLineMK
    SLineMK Member
    49
    I called Audi in Milton Keynes as my MMI said it was full 800 miles later empty... They told me that for my 2.0T 211bhp it is normal to burn that much oil Crazy me thinks. They told me to buy a litre put half in and wait for the level to drop again before adding the other half.
  25. Mcdubber1
    Mcdubber1 Member
    255
    It's only normal because there is a problem that most of them seem to suffer from. The sooner they accept responsibility for the problem and cough up for the necessary repairs the better. You could ask for an oil consumption test to be done?
  26. ScottishA4B9
    2,975
    759
    Did u gave any results from yours Mcdubber1?
  27. Mcdubber1
    Mcdubber1 Member
    255
    I got my car back on Monday but unfortunately the first phase of the test wasn't carried out due to some modifications on my car. There's a modification to the inlet system that is part of the Forge dv which would need to be removed because I was told that part gets replaced as part of the first phase. Also the software update could wipe my remap so I told them not to go ahead with it for the time being, I don't want to risk loosing my current software until I find out if it can be uploaded again without having to pay again.ScottishS3 - how's is yours getting on since the first phase was carried out?
  28. ScottishA4B9
    2,975
    759
    It seemed it be ok initially now it's back to drinking the oil.
  29. ByronM
    ByronM Member
    Guys, what is the recommended oil we should be putting into the engine (2.0 TFSI)?
  30. ScottishA4B9
    2,975
    759
    5w30 Castrol Edge (Fully Synthetic)
  31. SLineMK
    SLineMK Member
    49
    I've been told 5w40 by Vagtech in Milton Keynes?
  32. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    2,809
    1,463
  33. Audi Dynamik
    2,218
    308
    5w40 or 5w30 either will do fine. I use 5w30 Castrol Edge.
  34. Crazyfool
    Crazyfool Lead boot
    1,062
    198
    Page 237 - 0.5l/1000km
  35. Crazyfool
    Crazyfool Lead boot
    1,062
    198
    That's complete rubbish because when I had my 1.8T serviced one year, they did a recall repair on the engine coils...How do they compromise on safety?
    I was amazed when they recalled my 1.8T, because this is a rarity. What Audi are good at doing though is not installing the problem components in the next generation of vehicles...nice!!
  36. ScottishA4B9
    2,975
    759
    Bloody Audi UK! I don't know why they are taking a totally different stance than Audi US, by totally choosing to ignore the faults with the 2.0TFSI engines and do nothing. Can't they see they will be loosing customers by this????
    Its not as if its a rarity the problem. It effects EVERY 2.0TFSI built between 2008-2011!
  37. rum4mo
    rum4mo Well-Known Member
    1,024
    180
    It will really be down to local territory consumer laws, also depends on who owns the local Audi importing company, don't just assume that Audi UK and Audi US are owned by Audi in Germany, it is possible they are owned by a private company. Until VW took ownership of VW UK back in the '70s (maybe), it was owned by Tiny Roland.
  38. daled
    daled New Member
    I have one of these bought thru' my local Audi dealer. I asked about this issue when I took delivery in January and was told " if it becomes an issue let us know and we can do the test"
    Guess what it was an issue, approx. 5 litres in 4 months so in it went, failed the consumption test and has just has new pistons, rings and conrods courtesy of Audi UK covered under the warranty as it was approved used stock.
    Since done oil consumption is nowhere near as bad and I don't know whether it is an illusion, fuel consumption is slightly better as well.
    Any way so far so good for me, but I will keep my eye on the oil level
