Evening all
el_man Sep 9, 2013
  1. el_man
    el_man New Member
    Hello, im pretty new to this sort of thing i used to own a 300bhp starlet and now have a 04 diesel dsg a3 and i love it got a few extra leather bose all that, im having a few problems with it tho nothing major just after abit of advice, first one is my time clock and mpg resets every few days no idea why :S ? another problem is the car starts on the click of a button when its cold but when its hot it takes its time to start, the battery is fine anyideas?
    cheers
  2. mjr901
    mjr901 Guest
    Hot start problem is common, new starter needed.
  3. el_man
    el_man New Member
    I had the car plugged in ny a mate and it comes up cylinder 1 and 4 glow plug electrical fault anyideas? i might throw some glow plugs in
  4. Artimus
    Artimus Shortback
    2,017
    485
    Welcome to the ASN mate.
    There are two trip computers, number 1 resets an hour or so after switch off, number 2 only resets when you manually reset it, they're cycled using the button under the wiper stalk. Look for the little symbol in the corner of the DIS to distinguish between the two & it's always best to Read The Manual for details.
  5. el_man
    el_man New Member
    Will that affect the actual time resetting tho?
  6. Artimus
    Artimus Shortback
    2,017
    485
    No, probably not.
    What year\model A3 is it?
  7. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    hot start map may be needed
  8. el_man
    el_man New Member
    its a 2004 bkd engine code
  9. el_man
    el_man New Member
    more problems with this car i had the flywheel changed because when i accelerate there was a knocking noise, so changed the flywheel and the exact same noise is there? more happens on the motorway any ideas? goes into gear fine and everything, and the second u let go of the throttle there no noise
  10. el_man
    el_man New Member
    should i of stuck with my jap motor haha anyideas?
