Evans waterless coolant in an S3? Any experiences?
s3facelift09 Nov 14, 2013
  1. s3facelift09
    s3facelift09 Member
    244
    23
    [h=2]Benefits Over Water-Based Coolants[/h] [h=3]Eliminates Overheating[/h] Evans Waterless Coolants have a boiling point above 180°C and will not vapourise, thus eliminating overheating, boil-over and after-boil.
    [h=3]Reduces Pressure[/h] Evans Waterless Coolants generate very low vapour pressures reducing strain on engine cooling system components.
    [h=3]Prevents Corrosion[/h] Evans Waterless Coolants contain no oxygen effectively eliminating corrosion.
    [h=3]Increases BHP[/h] Evans Waterless Coolants eliminate pre-ignition and detonation caused by overheating - thus improving combustion efficiency and delivering more power.
    [h=3]Stops Erosion[/h] Evans Waterless Coolants prevent cavitation and eliminate liner and cooling pump erosion.
    [h=3]Freeze Protection[/h] Evans Waterless Coolants freeze below -40ºC
    [h=3]Non-Toxic[/h] Evans Waterless Coolants are proven to be Non-Toxic. Standard anti-freeze is toxic and known to kill pets.
    To go for, or not to go for?
  2. T-800
    T-800 Well-Known Member Team Mythos VCDS Map User Team Tornado Audi RS3 quattro DSG
    1,558
    1,226
    Now that's interesting.
  3. Boon
    Boon Active Member
    441
    59
    Who makes it?! :whistle2:
    sliced and LEE69 like this.
  4. Muzza80
    Muzza80 Well-Known Member
    699
    336
    Hmm, looks like good stuff!
  5. s3facelift09
    s3facelift09 Member
    244
    23
    Evans Cooling Systems UK, Swansea.. they have a good web-site with a large FAQ where everything is explained..
  6. Marshy
    Marshy Settled in Audi RS3
    1,352
    468
    If it does what it says 100% yes
    How much?
  7. Muzza80
    699
    336
    £65 for 5L
  8. Marshy
    1,352
    468
    If money's not a problem it'd be good to try.
  9. gixerson
    gixerson Member
    124
    Can't remember the exact brand, but i have tried waterless cooling liquid and ended up throwing it away.
    It was a pain to fill as you need to flush out the old coolant and let it dry,
    The car then ran a fair bit hotter with this stuff
    Absolute waste of time, money and effort
  10. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,072
    60
    Evans do say on their website that the engine will run a few degrees hotter.
  11. S3Alex
    10,474
    4,523
  12. nluk100
    nluk100 Active Member
    900
    163
    43
    How will it increase performance exactly ....?
  13. S.
    S. Well-Known Member Team Ibis TFSI Owners Group Audi S3 quattro Manual
    1,950
    513
    same probably as go fast stickers :D
    s3facelift09 and Sevv like this.
  14. S3Alex
    10,474
    4,523
    From what I've read it allows you to run the engine hotter,which may provide some increases,but also to eliminate hotspots and reduce the onset of knock,but I still don't think any of that will persuade me.
  15. s3_sid
    s3_sid Active Member
    368
    35
    nothing wrong with water and g12 has worked on millions of cars for years , if it was that revolutionary surely manufactures would make you use it ?
  16. Sidhu88
    Sidhu88 Active Member
    808
    76
    Its the cost factor. £65 for 5L is a huge difference compared to normal coolant.
  17. s3_sid
    368
    35
    Yeah but it only costs that much as they make a stupid mark up on it ! If they mass produced it their would be no reason drastically reduce the costs of production , and on high end cars if its for the life if the engine surely it would be cost effective
  18. Artimus
    Artimus Shortback
    2,007
    480
    If it's so good for the engine\environment & cost effective to boot, why aren't manufacturers falling over themselves to use it initially, instead of standard coolant? The same can be asked about internal engine\gearbox coatings like Slick 50, etc & coolant leak & rust inhibitors.
    There's usually a little known drawback not mentioned in the sales blurb for such things and I'd personally steer clear if you value your engine, unless\until it becomes manufacturer recommended.
  19. ACWKGYTO
    ACWKGYTO Well-Known Member
    1,232
    362
    They were pushing this in a major way at the NEC classic car show this weekend, expensive stuff, would need to be very good
  20. s3facelift09
    s3facelift09 Member
    244
    23
    Jay Leno has been using Evans for 16 years in his cars.. :blink: I hope they didn't just pay him to say that..
