etka help please.
RHODIE May 25, 2010
  1. RHODIE
    RHODIE Member
    277
    10
    I've just ordered an s3 and would like to remove the armrest and would like the part number for the blanking plate for the gap left when the armrest is removed. The reason I dont want the armrest is I am ina wheelchair and cant reach over the armrest.
    Thank you for your help.
  2. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Moderator
    5,920
    30
    There will be a few along later who will help you. On another note, i'm sure there are a number of guys on here after the armrest, you may have offers for it.
  3. a3_dan
    a3_dan Member
    588
    I need an armrest if you get round to selling mate, leather if available! :)
  4. Yaks
    Yaks Member
    181
    Can you get an S3 without an armrest ?
    I've ordered an S3, and the one thing I didn't like about the interior was the armrest - got in the way changing gear or applying handbrake. The salesman said I could raise it up, but still wasn't quite right, so would lik eto get rid if there was a neat solution.
    Anyone got a picture of what the "blanking plate" looks like ? Is it factory fit or dealer fit ?
    Thanks,
    Yaks
  5. aristides
    aristides Member
    550
    I dont believe there is a blanking plate guys
    You might have to buy the whole center console
  6. RHODIE
    RHODIE Member
    277
    10
    Dealer told me they could take it out but it would leave a hole - something I dont want. It used to be an option so I am assuming a plate should be available.
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    if it was an option they would have fitted the alternate centre console instead, however if you speak to those on here wanting to do the retrofit you may be able to swap out for theirs plus some cash to you
  8. mike foster
    3,967
    P5SND is right. The centre console has a different part number for with, and without armrest and there is no blanking plate available.
    There are however usually dozens of guys on here wanting to fit the armrest so you shouldn't have much problem getting sorted. Reasonably easy job to remove the centre console and re-fit the new one. An hour should see it done.
    Good luck !
  9. PH1L
    PH1L Gievf Buckets
    3,851
    40
    as mike says an hour would remove one even if you didnt know what you were doing and chances are if someone wants to retrofit one they do, so alll that would be left is to find one close to you, however i suggest you sit in a s3 or a3 without one looks wrong imho
  10. RHODIE
    RHODIE Member
    277
    10
    Dealer ordering a new console and total cost fitted £160. I presume I can keep armrest and next owner can refitn it if they want to.
  11. PH1L
    PH1L Gievf Buckets
    3,851
    40
    make sure and keep the alternate centre console
