etka - front suspension and centre armrest
firestorm May 9, 2006
  1. firestorm
    firestorm Member
    371
    Hi,
    can someone with access to etka or equivalent post the following pages :
    for a 2002 A4 Avant (TDI130)
    1) centre armrest (the latch is broken:-| )
    2) front suspension (I am after the part number of the top mount rubbers and pinch bolts for the upper suspension arms)
    3) Something showing the rear under tray near the rear anti roll bar. I noticed whoever worked in that area before left out the majority of the screws...
    The diagram and part numbers will be perfect.
  2. FrankG
    FrankG Member
    160
    Can you identify which part you are after and I will get you the part number? [​IMG]
  3. FrankG
    FrankG Member
    160
    It looks like the Armrest isn't supplied with the catch only, you have to order the top or bottom complete? [​IMG]
  4. firestorm
    firestorm Member
    371
    Hi Frank,
    #46 on the second pic
    for the suspension, I can't recognise any of the parts! I'll try and locate some photos
    Thanks! [​IMG]
  5. FrankG
    FrankG Member
    160
    Hello Firestorm, Part No.46 has about 12 different finishes so the handiest thing for you id to register yourself with vagcat, see link below, it only takes a few minutes, then you will have all the part N's and drawings at your figure tips.
    http://www.vagcat.com/epc/cat/au/A4/
  6. firestorm
    firestorm Member
    371
    Thanks Frank, I'll do that.
