ET 45? ET35? DIFFERENCE?
vw754 Apr 27, 2007
  1. vw754
    vw754 vorsprung Durch Technik
    2,337
    58
    what is the difference ET35 and ET45?
    My car has the audi 5 star alloys on 17" they state et35 on the inside of the rim,i need one wheel as it is slightly buckled but ive been offered 1 that has an offset of et 45 instead of the et35 i need.
    Also i by mistake i purchased a brand new wheel same as i need which was ET56 which i was told will not fit as it will catch,its brand new and currently for sale on e-bay if anyone's interested
    GENUINE,BOXED AND BRANDNEW 50 QUID ! Item number: 320105199501
  2. icenutter
    icenutter Member
    596
    ET is just the offset. Imagine you are looking down on the top of the tyre; a wheel with a ET of 0 is exactly in the middle of the mounting plane (where the nuts go into). The bigger the ET number the more 'inwards' the tyre is.
    Changing ET changes the track, and also messes about with the suspension and steering geometry. 10 mm isn't a /massive/ change though. However, having different ET on different sides of the car, would probably be a bad thing.
  3. vw754
    2,337
    58
    i like my wheels level with the arch,i.e not sticking out of the arch like some drivers,at the moment et35's are on the car which look good,is this the rite et for the a4 (b6)? so basically if et 45's were fitted they would sit more inside the arch rather than level with the arch?
  4. AJO
    AJO Member
    135
    you are correct. the higher the offset the further in the wheel sits
  5. joost
    joost Active Member
    1,169
    10?
  6. JGrant1285
    JGrant1285 Sir Scouser Benitez
    225
    I would like to know what ET my wheels are....should it say on them? If not is there anyway that i can measure them? What is the ET Measured in any idea?
    I'm looking at getting wider tyres this time round, but i need to know what ET mines are so i can check that they wont catch.
  7. S3Steve
    S3Steve Active Member
    1,621
    19
    ET should be stamped on the wheel somewhere.
    ET is the distance from the centre line of the wheel to the mounting face, measured in mm.
    When going to wider wheels you normally have to decrease your offset to ensure they dont catch on the strut.
    fanta likes this.
  8. 45bvtc
    45bvtc Well-Known Member Supporter Team Daytona Team Sahara Silver Gold Supporter Team Cornflower Blue Audi RS3 Audi TT Audi A1
    3,777
    5,109
    I prepared this drawing to explain ET for 8P Audi RS3 owners; just substitute your own measurements:
    Hope this helps...
  9. T-800
    T-800 Well-Known Member VCDS Map User
    1,668
    1,350
    http://www.willtheyfit.com/
