  1. tony-b-3.2-v6
    tony-b-3.2-v6 Member
    120
    Hi guys just a quick one i was out driving in the snow today wheels spun a bit and the esp light on my dash started to flash, I just want to no is the light on the dash suppose to be on for the esp to be active or should it be off. Ive got an esp on/off button on my dash but dont no if the light should be on or off thanks in advance.:confused:
  2. beanoir
    beanoir Large Member
    2,171
    31
    The light (orange with picture of a car and skidmarks) will not normally be lit on the dash unless you activate the ESP by the wheels losing traction in which case it will start flashing whilst the system is trying to prevent the wheels spinning, and then it will go out once you regain traction.
    The ESP is on by default everytime you start the car, and the light will not be lit.
    In practice the wheels will still slip a bit with the ESP engaged, but nowhere near as much as when you turn it off.
  3. smudge_don
    smudge_don Active Member
    2,944
    Turn it off in the snow, much more fun ;)
  4. tony-b-3.2-v6
    120
    I no that but the wife doesn't think so:lmfao:
  5. glossy555
    glossy555 Member
    49
    right job;):respekt:
  6. Hellz
    Hellz Geordie Racer
    381
    Should the ESP light flash intermittently under braking where the ABS has kicked in?
    Mine flashes when pulling away and its scrambling for traction and I'm sure it used to flash under heavy braking but noticed when coming home today, I braked hard in the snow, the ABS kicked in but the ESP light didnt flash... now im questioning whether it used to or not!
  7. ianspibs
    ianspibs Member
    119
    It also tells you in the manual to turn it off in the snow.
  8. A3Bash
    A3Bash Member
    169
    It may have been flashing before because the stability control was stopping the car going sideways under heavy braking.
  9. A3Bash
    A3Bash Member
    169
  10. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Crazy, I turned mine off in the snow the other night leaving work for the hell of it - didn't boot it that hard, and the car drifted several feet across the car park! Now I leave it on...
  11. waqi
    waqi Member
    150
    much more fun in the snow with it off.. especially when used with a soft right foot and quick left hand :D
    make sure you take care and be safe!
  12. waqi
    waqi Member
    150
