ESP... Why would I ever turn it off?
Agent_Trig Oct 21, 2011
  1. Agent_Trig
    Agent_Trig Member
    552
    Might be a dumb question, but this is the first car I've had that's had ESP and I'm trying to work out what situation would I need to be in where turning off the ESP would be to my advantage?
    When do you turn it off and why?
  2. a3tdi2001
    a3tdi2001 Member
    437
    You can get better traction when trying to get going in the snow, or when rocking the car back and forth to free it if you're stuck. Other than that you're better with it switched on. Listen to uncle Tiff: Fifth Gear ABS, TC, ESP Full version - YouTube
  3. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,267
    360
    i was just about to post that video up :(
  4. danb986
    danb986 In awe of VCDS Team Daytona
    523
    Totally agree with the snow bit.
  5. Agent_Trig
    Agent_Trig Member
    552
    Cool, so its mainly used to keep the car on the road under heavy steering in bad conditions but back to my question - Why would I ever want it off?
  6. danb986
    523
    I found that if I was stuck in the snow it would pull away a lot easier if you turned it off.
  7. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,230
    153
    Triggy
    Next time you are stuck in the mud or snow or on a track day.........you would want to switch it off :) it does dull the performance as well as not helping in the snow/mud
  8. h5djr
    9,423
    1,747
    Perhaps you might want to try and drive at the limit and see who wins - You or the Ditch!!!
  9. 1inchpunch
    1inchpunch Member
    451
    This simple equation explains it
    TDi + DSG + traction control x snow = going nowhere
    TDi + DSG - traction control x snow = a chance of movement
    The only time this equation does not work is when you add rear wheel drive to any of the above.
    Give it until the snow comes and you will be praising the heavens for that off button.
  10. hades-
    9,481
    646
    as above snow mud etc
    or to have a bit of fun
  11. a3tdi2001
    a3tdi2001 Member
    437
  12. marknjayne
    marknjayne Member
    425
    proper drivers turn it off :arco:
    A to B drivers wont get that
  13. LWNY
    LWNY Member
    161
    Go too fast into a corner, and when you hit the gas, ESP will sense you are not going in the direction of the steering wheel and it will feel bogged down. With it off, you will likely have to adjust the steering more, but you can get more power to your wheels and accelerate yourself out of the turn.
    Go too slow into a corner, and when you hit the gas, ESP will apply as much power as possible short of spinning the wheel out and accelerate you out of the turn. With it off, and especially if you are on the peak torque region of your engine, you will likely spin the wheels out and not carry yourself out of the turn as fast.
  14. marknjayne
    marknjayne Member
    425
    looks like you are not an A to B driver :racer:
  15. moag
    moag she's no d-turbo
    821
    35
    Only time i've had it off is in the snow. ESP performed surprising well in the snow last year but sometimes it needs switched off to get going
  16. MTW
    MTW Member
    210
    mine doesnt work :hi:
  17. TM
    TM S-line SB
    144
    Is that SB being held up by a tree!! That would of been some scary sh*t!
  18. Rob-Quattro
    Rob-Quattro Member
    225
    13
    4 wheel launches with Quattro :whistle2:
  19. crunchie
    crunchie Active Member
    880
    77
    Its more fun with if off but it has also saved me a few times so......
  20. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'm afraid it will need sorted for next years MOT as it will now be a testable item.
  21. marknjayne
    marknjayne Member
    425
    how the hell would they test it,by going out and giving the car the beans to get it to kick in, think its another one just like the "if your car has been remapped it wont pass" rubbish
  22. Khufu
    5,704
    31
    It will be just a simple test: When you log a vehicle on for an MOT the Vehicle Specific Information will instruct on how the system should work, eg a warning light should come on & go out after 2 seconds etc. If a light stays on or doesn't come on (eg somebody has removed bulb/wiring etc) then it will fail. Same will go for the airbags too. Its just the same way they test the ABS the now. As long as the warning lights do as they should you will be fine even if the items dont actually work LOL
    checking for a remap IS rubbish :thumbsup:
  23. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,236
    331
    as said only turn it off in the snow , my light is on best i get saving to get that sorted then eh lol
  24. marknjayne
    marknjayne Member
    425
    what if you remove the button and replace it with a blank,just like a spare,if you dont have it it will pass but if you have it and its flat/worn it wont,not that i see a point to removing the switch but "hypothetically" because not all cars have T/C or ESP
  25. Khufu
    5,704
    31
    Thats what the VSI is for - its data from the manufacturer on what certain models should have fitted. If its an option for a model then removing the button & light could work unless it gets its data from the VIN number as opposed to the model. In the case of the 8P A3 they all have it as standard so the VSI will say this and it will be required where say for a corsa it will say 'if fitted it must meet the requirements'.
    Though not yet confirmed as VOSA are still in talks with the goverment, the changes to the MOT for 2012 could be advisories for the 1st 6 months.
  26. flying oyster
    flying oyster flying oyster
    563
    27
    why switch it on its so much more fun to drive without
  27. LWNY
    LWNY Member
    161
    Depends if you have FWD or quattro. Turning it off on FWD will just result in alot of plowing. Turning it off on a quattro will allow all both axles to spin, resulting in 4 wheel drifting. To bad you can't turn off ESP w/o turning off traction control, since the inner wheel will frequently lose traction first and you can't gain any more speed from increased throttle.
  28. Ben H
    Ben H On a journey...
    365
    19
    If you have an S-Tronic (DSG) gearbox, then it's essential to disengage the ESP if you want to exercise the launch control mode. ;)
  29. Agent_Trig
    Agent_Trig Member
    552
    Thanks for the advice guys.
    I never really drive the car that hard to be fair so I'll wait till the snow comes to test this out :)
