ESP lights and misfire 2002 3.0L CVT
miron Dec 6, 2011
  1. miron
    miron New Member
    Hi
    Short time after starting the car (usually on the first step on the brake pedal) the ESP light comes on and causing misfire , idle is jumping up and down and even engine going off when I stop. the light is not going off even if I turn off the engine but only after driving about 10 KM.
    I went to Audi dealer and we saw many error codes (also MAF) , MAF was replaced but was not helping at all, same codes were coming again.
    I do not have all codes now (I will try to get them from the dealer) but it seems to me that the ECU is sending rundom codes.
    Did anybody face this problem?
    thanks
    Miron
  2. miron
    miron New Member
    The throtle position sensor had to be reset.it solved the problen
    Miron
  3. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,202
    160
    Glad you got it sorted. Hopefully someone will see this in the future and you've helped them out.
