esp light
Discussion in 'A3/S3/Sportback (8P Chassis)' started by chiefkris, Apr 4, 2014.
  1. chiefkris
    Offline
    chiefkris New Member
    Jan 23, 2014
    19
    My esp light has come on. The cars showing no fault codes and I've cleaned the maf as I heard that could be it. It hasnt worked, any help as too what it could be?
    #1
  2. Artimus
    Offline
    Artimus Short Back
    May 9, 2012
    1,887
    362
    I'm near certain there was an ESP thread only last week! Have a search.
    #2
  3. Best84
    Offline
    Best84 Member
    Feb 17, 2012
    137
    Out of interest...why would the maf throw the esp light?
    #3
  4. SmithyAG
    Online
    SmithyAG Active Member
    Dec 22, 2013
    385
    59
    What did you scan the car with? Not all readers communicate with the abs/esp Ecu. So they show no faults in the main ECU but one could be logged in the other.
    #4
  5. Dave-S3
    Offline
    Dave-S3 Active Member
    Jun 13, 2012
    577
    116
    What car do you have?
    #5
  6. chiefkris
    Offline
    Jan 23, 2014
    19
    Scanned with the liquid gauge I have and it's a 2006 2.0 tfsi
    #6
  7. SmithyAG
    Online
    Dec 22, 2013
    385
    59
    Like this one Race Diagnostics Ltd - liquidA3/S3 opions ?
    Although it looks a nice bit of kit that can read a lot of sensors, it doesn't specifically say it reads the codes from the ABS ECU, so may be that's why it isn't showing a fault. If the ESP light is on to indicate a problem then there will be a code somewhere, is there no information shown on the DIS (if your car has it)?
    #7
  8. chiefkris
    Offline
    Jan 23, 2014
    19
    That's the one! Ah I see I'll have to take it to be scanned then. Nope every time I turn the engineon the light comes on and it just says refer to manual
    #8
  9. Dave-S3
    Offline
    Jun 13, 2012
    577
    116
    Sounds like it could be the G201 pressure sender fault 01435, was common around that era of VAG models, there is a VAG oem repair kit out now (when i had the fault there wasn't such a repair kit and it was either a new ECU at £1500 or a recon one at about £600 fitted) The repair kit is about £150 now i think. Sure someone else will be along soon with some more info, it might not be that though!
    #9
  10. Mikemc
    Offline
    Mikemc Active Member
    Oct 24, 2012
    987
    32
    Yea I had the repair kit on mine, was about 170, and few hours labour job done, sure the brake fluid needs changing at same time too
    #10
  11. Dave-S3
    Offline
    Jun 13, 2012
    577
    116
    Yeah the brake fluid needs changing too.
    #11
