ESP Light staying on
dirtydamdog Apr 3, 2011
  1. dirtydamdog
    dirtydamdog New Member
    9
    Just had the car serviced and after about 100 miles the ESP light has decided to stay on. Wot causes this problem and does this also mean the whole sytem is no longer working eg ABS, tration control etc??
  2. pat_986
    pat_986 Member
    67
    Could be loads of things at fault, wheel sensors, steering angle sensor......... you will need to have it scanned
  3. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    I'd get it scanned first. Saves alot of guessing.
    In the servicing, have they done tracking (rare i know)
    Is the steering wheel in a different place?
  4. vr6gordy
    vr6gordy Well-Known Member
    2,826
    191
    mind was doing this and i put new brake light switch in hasnt come back on
  5. Mike B
    Mike B Well-Known Member
    1,114
    40
    same here 2 mos ago
  6. dirtydamdog
    9
    Yeah they did the tracking as i had new shocks fitted in the service. Maybe this has set the fault off I'll get it scanned and find out the codes.
  7. Mike B
    1,114
    40
    Mine only scanned as a drivetrain fault and as the brake light switch can be suspect and is cheap and easy to fix tried this and ok so far
  8. quattrojames
    14,060
    583
    Brake lights are the most common cause of this, and the easiest to check. It could be a blown bulb or the pedal switch, easy to check.
