esp light staying on cutting engine out
kendo01 Oct 27, 2007
  1. kendo01
    kendo01 New Member
    2.5 tdi multitronic esp light came on engine running like a bag of nails wont pu;ll and cuts out,light sometimes goes out and runs ok until you put foot on brake and select drive please help ,did this a few months ago left it a few days and was perfect up until two days ago
    no engine management light on:sadlike:
  2. motosparkz
    motosparkz Member
    50
    Hi Kendo01,
    You really need this on a diagnostics machine or vagcom, although I have come across similar before, although not to the extent of the engine dying, & this was down to the infamous brake pedal position switch.
    What sounds like is happening is the esp etc is getting 1 signal & the engine another. It is also the brake pedal position switch which stops you over-revving it in neutral or with your foot on the brake, (in this case the revs should come down when you touch the brake, bit of a ****** for left foot braking though<S>).
    I would probably say it's only that, but you really meed it diagnosing to confirm.
    Hope this helps, & although it seems severe, it's probably a £10 sensor/switch at worse.
    Shane, (York)
  3. golf
    golf ***** rent boy VCDS Map User
    1,556
    It could be the crankshaft sensor.
