ESP light just came on!
Slick S3 Apr 11, 2007
  1. Slick S3
    Slick S3 Member
    131
    Driving back from work and i noticed my ESP light was on, tried pressing the button but no joy, light was still on.
    Checked the brake lights and there working.
    Incidentally i have just the day before changed both front cv gaitors and a wishbone...so everything was taken out....apart from any sensors on the wheel. However aparently after changing the wishbone you need to get the camber alignment done? (which is prob why the steering angle is not staight to the wheels)
    My steering wheel is not striaght now when the wheels are straight, and the mot guy said i need to get my tracking done as it is out.
    Knowing that the esp is connected to the steering angle and tracking of the car does anyone think that if i get all that sorted it should rectify the problem.
    Any help would be much appreciated.
    Also both front pads and dics's were removed when doing the cv gaitors.:readit:
  2. Slick S3
    Slick S3 Member
    131
    I also just got my car washed the previous day and they used a pressure washer!
  3. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Know anyone with VAGCOM? Get it plugged in and save ages hunting around for the problem.
  4. Slick S3
    Slick S3 Member
    131
    not personally....anyone with a vag-com near nw london wanna help out:think:
  5. madvw
    madvw Active Member
    2,489
    getting the steering angle sensor calibrated is critical for ESP. There is a procedure for resetting this somewhere... it needs vag-com though.
    dont know if this would cause the ESP light to come on though. Vagcom it as a4q says though to be sure.
  6. Slick S3
    Slick S3 Member
    131
    Can this only be done using a vag-com or can it be done at a good tyre place that do the camber and tracking for the wheels....
    Is this to be done because i changed the wishbone and threw out the steering angle...cos it's not straight now!
