ESP light: HELP!
t30gue Jun 29, 2004
  1. t30gue
    t30gue Member
    47
    Got a 2000 'W' S3, managed to get hold of the newer facelift model steering wheel. Since changing it over have had the dashboard ESP light on. Has anyone here changed to a later wheel? Did you encounter this problem? Or have I made a silly mistake? Is this wheel is compatible with my model car?
    Please help as light is starting to get on my nerves! I don't want to take it to the Stealer to sort!
    Thanks.
  2. imported_bayliss
    imported_bayliss Guest
    could this be due to the airbag needing reset???
  3. t30gue
    t30gue Member
    47
    Airbag light was reset using vagcom, but ESP fault would not clear.
  4. imported_bayliss
    got me then sorry fella!
  5. AndybS3
    AndybS3 Member
    233
    Whats the fault code?
  6. t30gue
    t30gue Member
    47
    Don't know what code is. I was told that the vagcom detected the fault, but no code was given???? I don't know if that makes any sense to you. I'm not that up on this kit.
    Does anyone know if the later wheel is def compatible with earlier cars??
  7. My esp light came on with my n75 valve problem. Does it go off when you switch off and on, ie reset?
  8. dickys3
    2,954
    Chris,
    You said that your car seemed down on power also, I think the n75 would cause this (Correct me if I am wrong guys).
  9. Drill
    Drill Member
    928
    Isn't there an ESP sensor in the wheel that detects it's position?? If it were bad or not wired in correctly, an ESP fault would result /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/crazy.gif
    /ubbthreads/images/graemlins/beerchug.gif
  10. S3_MCD
    S3_MCD Member
    389
    [ QUOTE ]
    [/ QUOTE ]
    I thought that the sensor in the Swheel was set lower down, nearer the indicator stalks (2 plastic coils that pass over each other to detect position - its these that caused my "clicking" problem on steering).
    Possible though to have disconnected part of this ESP sensor setup when changing Swheel, might be the reason for givin a fault code on trhe VAGCOM?!? i.e. nothing to detect?!? /ubbthreads/images/graemlins/confused.gif
  11. If you have upset the steering angle sensor when fitting the wheel it needs to be re-programed. Can only be done at the dealer. /ubbthreads/images/graemlins/wink.gif
  12. t30gue
    t30gue Member
    47
    Dealer it is then! Whats this about the n75??? or rather what is the n75, and how do I reset this? as car feels slower, or held back (if this makes sense)
    Perhaps I have 2 faults.....great!!!
  13. t30gue
    t30gue Member
    47
    Everything fine now! Steering angle sensor was broken/Damaged when I swapped the wheel?? Can't think how I done this,as I was very careful, but stealer fitted new one and everything is great again! /ubbthreads/images/graemlins/smile.gif
    Warning: be careful with this as replacement part is £160 + the tw#t!(VAT)
    How nice it was of the Dealer to have one on the shelf!
    Thanks for help guys!
