ESP light comes on when accelarating??
Rob_B Jun 20, 2011
  1. Rob_B
    Rob_B Member
    192
    got a little issue with my s3, the esp/traction control light comes on when accelarating at speed
    if i put my foot done in 6th at 60 mph and accelarate to 70-80mph the yellow light comes on, nothing happens, apart from the light coming on and staying on
    when i shut the engine off and start it back up again the light goes out, and only come back on again when i do the same thing
    any ideas guys?
    regards
    rob
  2. Westy
    Westy Well-Known Member
    17,443
    1,104
    Sounds like a wheel speed sensor issue. You'll need to get your car scanned to be able to find out which wheel sensor it is.
  3. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Have you had suspension work done? sometimes this puts the light on until it has had the tracking done.....
  4. jcs356
    jcs356 Brum brum
    2,726
    67
    Could also be lateral/longitudinal acceleration sensor. As W3STY says, you need a VCDS scan to tell you for sure.
  5. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Agreed - get it scanned.
    When my wheel speed sensors have come on in the past both the esp and abs lights have come on and the car has been proper sketchy under braking.
  6. bazil
    bazil BOOM BOOM
    135
    would that be a frightening surging of braking followed by no brakes etc? had similar myself, but it was my longitudinal sensor that was gubbed,
    as said above many times, get it scaned, you could waste ALOT of money throwing parts at it that it wont need.
  7. Prawn
    11,536
    3,480
    I'd hazzard a bet that you're all wrong :D
    It'll be a fault code saying MAF signal too high
    This often happens of you add mods after a stage 1 remap, as the car is able to reach higher load values on the ecu than when first mapped.
    Mine does this since adding a TIP and 3" dp after a stage 1 map, nick (rtech) said it was something to do with going over 185% load.
    It only does it very rarely, and only in 4th or 5th and only on 95 Ron fuel.
    I'd bet any money that's what it is
  8. Essflee
    Essflee Well-Known Member
    2,146
    67
    Yeah, this used to happen on my car, 4th, 5th and 6th, when scanned it would show 'maf signal to high'.
    Since i've had a new engine fitted and had the boost dropped a bit I've never seen this fault come up.
  9. Sam_
    Sam_ Down under
    3,038
    480
    Could also be the infamous G200 sensor. Mine done exactly this. Turned out someone had bent the bracket.
  10. Rob_B
    Rob_B Member
    192
    car has had suspension work all new ball joints, front wishbone bushes and arb bushes, i have had it tracked up but it still does it
    soon after i had the new bushes fitted when going over bumpy roads the traction control light would flash and activate as though i was wheel spinning even though it wasnt losing grip - however this problem has gone now
    i have had the car on the scanner and it didnt have any fault codes for the abs or traction control system, loads for the enigne but thats because i have just fitted a new engine
    so it could be the maf issue prawn talks of, how do you go about fixing it? i have had the mods done on my old engine and there was never an issue but with the new BAM engine it seems to - i also think there is a boost leak, would this cause the maf fault?
  11. Prawn
    11,536
    3,480
    it's definitely the MAF signal too high code mate, I'd put money on it.
    it's not a problem though, it's just something that happens because you're making more power than it's expecting to make.
    have you fitted a large port engine where it used to have a small port by any chance? as that'd certainly make it happen.
    either way, it's not doing any harm, and there's certainly nothing wrong with it, so I wouldn't worry
  12. Rob_B
    Rob_B Member
    192
    I had a amk engine and blew it on a track day, so i then purchased a BAM engine from a LCR, refreshed all the bearing and pumps
    is it true the BAM has larger ported head??
  13. Dane
    4,086
    182
  14. SteveBAM
    SteveBAM Black '03 S3
    180
    i have had the same problem for a long time now, under heavy acceleration the traction control light would come on but would not always do that. i have a koni suspension lowered with h&r springs but i really didn't think it had anything to do with that, it all started when i added an inline fuel pump (my oem one went bad) and also installed a second hand oem pump,engine was been over fueled and the esp indicator was going on(not really sure..!!) a few weeks ago i pulled out the inline pump and it hasn't gone on since..:thumbsup:
  15. Rob_B
    Rob_B Member
    192
    well i have solved my boost leak and its sorted this issue out too...touch wood
