ESP light come on and wont come off
James88 Mar 30, 2010
  1. James88
    James88 Member
    44
    More faults with the bloody A4 :(
    Any ideas why it come on ??, before i fork out 60+vat for vagcom :(
    i looked around the forum and some did say it could be the brake pressure sensor, but no abs light coming on mine
    i be grateful for any feedback :)
  2. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    The list could be endless! You need to get it on vagcom to find out where the problem is.
    On mine it was the yaw sensor under the centre dash.
    Could be the brake switch but iirc that brings up the abs light too.
  3. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    17
    As per BlackQuat - VAG-COM it - best investment you can make on your Audi - will save you loads in the future.
    There maybe a forum member near you with VAG-COM for a quick scan?
  4. quattrojames
    14,068
    585
    Most likely a brake light switch, but you will need VAG-com to confirm.
  5. James88
    James88 Member
    44
    Cheers fellas for the quick replies, theres a audi specialist near me called dialynx performance i pop down there tomorrow :)
  6. James88
    James88 Member
    44
    23 quid inc vat for vagcom fault check, not bad me thinks, found that the sensor needs replacing and about 200 quid to fix it :(
  7. AudiLeon
    2,250
    192
    Which sensor and what part number.
  8. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    another 10 of them and youd own your own cable.
  9. quattrojames
    14,068
    585
    You gotta be on commission......
  10. James88
    James88 Member
    44
    i completly forgot mate, i email them later and ask, they did say its something to do with abs and eps controller sensor or something
  11. AudiLeon
    2,250
    192
    Find out bud, I have a brand new YAW sensor here for less than 200. If you need one.
