Esp light/climate/key fob opening/ help!!!!!!
sabs46 Jan 15, 2011
  1. sabs46
    sabs46 New Member
    24
    Hi guys,
    Yes i have the above probs.I know they get discussed a lot but i am now pulling my hair out...
    1. First got esp light on dash, climate control turns off and indicators did not register on dash but did work.(started intermittent but now all the time)
    replaced brake switch as suggested ..no effect
    2. key fob stops opening door, opened car(well my father did as i was away) manually, alarm sounded i believe. Battery ran flat, i assume indicators were left flashing (which they now constantly) as alarm was triggered.
    3. read articles suggesting car battery fault, replaced battery no dif.o and tried reprogramming remotes didn't work
    4. ran diagnostics cleared faults, came back with:-
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AC Component: A4 Klimaautomat 1424 Coding: 00000 Shop #: WSC 63351 VCID: 62C0798CC4C9
    No fault code found.
    Cleared and ran another:-
    -------------------------------------------------------------------------------Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 S Component: Lenksáulenmodul 0611 Coding: 01011 Shop #: WSC 63351 VCID: 438E9C087B13
    -------------------------------------------------------------------------------Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl Part No: 8E0 959 433 BD Component: Komfortgerát TBF 1712 Coding: 06859 Shop #: WSC 63351 VCID: 74EC0FD46E3D
    Part No: 8E2959802B Component: Tõrsteuer.FS BRM 0205
    Part No: 8E2959801B Component: Tõrsteuer.BF BRM 0205
    No Faults Found or DTCs not supported by controller or a communication error occurred
    So before i start pulling money for dual climate or/and steering column control..
    Any ideas please..........:ermm:
  2. sabs46
    sabs46 New Member
    24
    Tried another diagnostics check after checking fuses( strangely interior ligt started working again as had been off, fuse was ok tho)
    Saturday,15,January,2011,19:07:39:09663
    VCDS Version: Release 10.6.3
    Data version: 20101206
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8EX5A058553 Mileage: 73130km/45440miles
    Coding: 00000
    Shop #: WSC 63351
    VCID: 62C0798CC4C9
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 J
    Component: Airbag 8.4EP 1002
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    VCID: 3E78EDFC10F1
    Coding: 01011
    Shop #: WSC 63351
    VCID: 438E9C087B13
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 M
    Component: KOMBI+WEGFAHRS. RB4 D42
    Coding: 00401
    Shop #: WSC 00762
    VCID: 336ECCC82BB3
    WAUZZZ8EX5A058553 AUZ6Z0D0326259
    1 Fault Found:
    00457 - Control Module for Network (J519)
    49-00 - No Communications
    Coding: 06859
    Shop #: WSC 63351
    VCID: 74EC0FD46E3D
    Part No: 8E2959802B
    Part No: 8E2959801B
    No Faults Found
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 M
    Component: symphony II PM6 0410
    Coding: 01201
    Shop #: WSC 00512
    VCID: 3162C6C0D1AF
    End ---------------------------------------------------------------------
