ESP light and ABS on after brake switch is replaced
polar Aug 27, 2010
  1. polar
    polar Member
    86
    HI all,
    I have just changed the brake pedal switch after my ESP and ABS light stayed on.
    The trouble is the ESP and ABS light are still on any ideas.
    Car booked in with AUDI next week....£75.00 just to look at the car.....help
    A4 Cabriolet 3.0 sport 2003
  2. quattrojames
    14,050
    578
    Do the brake lights both work ok? I've seen the error occur with dodgy bulbs too.
    Its impossible to guess without a scan really, was it a scan that told you the switch was dodgy?
  3. polar
    polar Member
    86
    I haven't had a scan, I took an informed guess and replaced it. Only took 10 Mins
    I live in Gosport near Portsmouth. Anyone know any independants
  4. polar
    polar Member
    86
    No more replies....off to Audi to take a look. Only charge £72 an hour
  5. AndyMac
    9,832
    46
    Take it to JKM (near Portsmouth Audi) they are excellent and £45 and hour
    So the lights were on before you replaced the switch, so likely the switch replacement is irrelevant. Could be so many things, ABS wheel sensors, ABS control module. If you get a scan and it can't communicate with the ABS module then it's probably a duff module. They can be repaired for around £130, but could be something far more straightforward
  6. paulsb
    paulsb Member
    138
    if you haven't been to audi before wedensday, give me a pm and i'll scan it for you.
  7. polar
    polar Member
    86
    Hi Paul.
    Are you in the Portsmouth area???
  8. rob irl tdi
    rob irl tdi Member
    240
    This came up in my friends a4. The esp light wouldn't go off so a new steering wheel angle sensor was fitted and ESP light went out. However the esp won't light up again when you press the button.
    The abs light use to beep 3 times and as far as I know the abs sensor was replaced. I couldn't make sense of the VCDS SCAN i took of it. I'll post his scan up later.
  9. paulsb
    paulsb Member
    138
    same happened to mine, had the tracking done and it was so far out i had to get the angle sensor reprogrammed as well.
    i live in scotland polar but i'll be in portsmouth for 3 days next week.
  10. rob irl tdi
    rob irl tdi Member
    240
    I tried resetting my friends steering angle sensor in VCDS. It wouldn't allow me to do it so he bought a new one.
  11. paulsb
    paulsb Member
    138
    you can't clear the fault code, you have to reprogram the sensor with 3 5 digit codes(engine, gearbox and brakes if memery serves). you need to have the codes before you reprorame the sensor. same goes for everytime you unplug it as well.
    but then again it might not be the steering angle sensor.
  12. rob irl tdi
    rob irl tdi Member
    240
    This was his scan. Car drains the battery the whole time too
    Sunday,30,May,2010,21:04:18:20000
    VCDS Version: Release 908.0
    Data version: 20090911
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUZZZ8E Mileage: 193580km/120285miles
    Address 01: Engine Labels: 038-906-019-AVF.lbl
    Part No: 038 906 019 FP
    Component: 1,9l R4 EDC 0000SG 1467
    Coding: 00002
    Shop #: WSC 63351
    WAUZZZ8E12A062793 AUZ6Z0A0151900
    No fault code found.
    Readiness: 0 0 X X X
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517
    Component: ABS/ESP front 1726
    Coding: 04255
    Shop #: WSC 00598
    2 Faults Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    00778 - Steering Angle Sensor (G85)
    37-10 - Faulty - Intermittent
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043
    Component: A4 Klimaautomat 0711
    Coding: 00000
    Shop #: WSC 63351
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 B
    Component: int. Lastmodul RDW 1512
    Coding: 00001
    Shop #: WSC 00000
    1 Fault Found:
    00532 - Supply Voltage B+
    53-10 - Supply Voltage Too Low - Intermittent
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655
    Component: Airbag 8.4E 3001
    Coding: 0010602
    Shop #: WSC 63351 000 00000
    1 Fault Found:
    002 - Lower Limit Exceeded - Intermittent
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 F
    Component: Lenksáulenmodul 0202
    Coding: 00011
    Shop #: WSC 63351
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 FX
    Component: KOMBI+WEGFAHRS. RB4 D28
    Coding: 00400
    Shop #: WSC 00000
    2 Faults Found:
    00668 - Supply Voltage Terminal 30
    01304 - Radio
    49-00 - No Communications
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0504
    Coding: 00001
    Shop #: WSC 00000
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Part No: 8E0 959 433 AL
    Component: Komfortgerát T9F 0514
    Coding: 06859
    Shop #: WSC 63351
    Part No: 8E2959802B
    Component: Tõrsteuer.FS BRM 4.11
    Part No: 8E2959801B
    Component: Tõrsteuer.BF BRM 4.11
    6 Faults Found:
    01330 - Central Control Module for Central Convenience (J393)
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01561 - Left Rear Door
    61-00 - Won't De-Safe
    01559 - Drivers Door
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    End ---------------------------------------------------------------------
  13. paulsb
    paulsb Member
    138
    have you check the battary, it might be on its way out. most of the above faults are for low voltage.
  14. rob irl tdi
    rob irl tdi Member
    240
    He put a new battery in and it still drains somewhere. Like he cannot leave it for over 2 days because it wont start.
    Getting back to this, he had the esp and the abs light on. Esp doesn't light up now when the button is pressed even with the new steering angle sensor. Maybe its a new SWCM is required?
    Abs beep was cleared by replacing a sensor
  15. sabs46
    sabs46 New Member
    24
    Hi i have similiar probs..if the diagnostic gives faults:
    01317 - Control Module in Instrument Cluster (J285) 49-00 - No Communications
    00466 - Control Module for Steering Column Electronics (J527) 49-00 - No Communications
    does it mean steering column sensor module is faulty??
    I have many probs, revolving mainly around the traction control, brake switch , climate control problem.. also total closure, computer, key fobs not working and alarm flasihng indicators manically when battery connected(have had to disconnect)
