esp fault
2010dang10
looking for some one in the ipswich sufflok with vcds vag com to check my faults.As esp is doing f all an car graping around corners can some one help
yes m8 just have done tracking then found that steering sensor at fault so replaced it.an then had it all reset still no esp.am now going to replace the latercel accelerater sensor and yaw sensor to see if that works ? .do you no if the esp is not working then i will not have ligth no dash.Because i have f all on dash even if i spin it up.was thinking that my consol it is not working as should do??
Grab yourself a cheap ebay lead and a copy of VCDS lite mate... scan for fault codes before changing stuff... could be something as simple as a wheel sensor..
Links to leads ect is in my sig... or in the stickies at the top of the 8L section
