ESP button not working after coilovers install - electronic damping delete solution?
114mph Dec 8, 2013
  1. 114mph
    114mph Member
    79
    19
    Hi,
    Recently installed coilovers on my 2009 S3 that had electronic dampers (same as "Magnetic ride"?), there is now a yellow warning light on the dash in the shape of a shock absorber.
    Q1 - Is there any way to code out this warning with VCDS?
    Q2 - Does this kit work? -http://www.moddedeuros.com/products/kw-edc-cancellation-kit-68510144
    The ESP button does not work when pressed, I scanned it with VCDS and no related fault codes came up. I'm assuming it is to do with the electronic damping fault?
    Q3 - Is there another way to reactivate ESP button without fixing the electronic damping fault?
    TIA
  2. NHN
    29,352
    1,720
    You've replaced your mag ride or you have fitted an electronic system to a standard spring/shock car?
  3. nluk100
    nluk100 Active Member
    994
    184
    43
    If you just swapped your mag ride for std coilovers then you may need to reconsider and buy the correct dampers for a mag ride car - why would you want to lose this useful feature?
  4. AdriansS3
    AdriansS3 Member
    77
    I installed kw coilovers to my 2010 S3 that had magnetic ride fitted for original owner( I didn't like them) and I bought a delete kit from them that plugs into the original wiring harness and mounts to a small box you mount in the wheel arch. It prevents any warning lights coming on. I suppose you could buy this separately even if you don't have kw coilovers.
    Adrian
  5. 114mph
    114mph Member
    79
    19
    Replaced mag ride with aftermarket coilovers.
  6. 114mph
    114mph Member
    79
    19
    These aftermarket coilovers are the most cost-effective way to drop the car to the exact ride height I wanted. What correct dampers for mag ride car are you referring to? I assume they would be quite expensive.
  7. 114mph
    114mph Member
    79
    19
    Thanks. Is this the same delete kit that came with your KW coilovers? Home Page ES#2608438 Electronic Dampening Cancellation Kit - 68510144
    I don't have KW but will probably get these if the warning light cannot be coded through VCDS.
  8. AdriansS3
    AdriansS3 Member
    77
    That looks like it yes. When my car went into an Audi specialist prior to me installing the delete kit they said they could not code it to stop the light coming on as without anything connected to the car wiring it was classed as an open circuit.
  9. NHN
    29,352
    1,720
    More than likely you could disable mag ride with vcds & disconnect the controller/switch.
  10. N8
    17,163
    718
    You should have bought KW DDC coils :laugh:
    NHN likes this.
  11. 114mph
    114mph Member
    79
    19
    Like AdriansS3 mentioned, have not yet heard anyone who was able to code/disable it through VCDS.
  12. 114mph
    114mph Member
    79
    19
    Not for 3 times the price. V3s are too expensive over here.
  13. N8
    17,163
    718
    Your driving an S3 with mag ride, I'm sure you could have arranged something :yum:
    sliced likes this.
  14. 114mph
    114mph Member
    79
    19
    I'm poor:p, bought the S3 used, V3 with EDC delete would have been almost 15% of what I paid for the car, can't really justify it.
