ESP button malfunction, maybe wire problem, someone post pic of connector?
emeraldA3guy Nov 18, 2010
  1. emeraldA3guy
    emeraldA3guy Member
    131
    So I might of swapped the cables around on my esp button.
    Can anyone post a picture of the connector with the wires connected to it?
    I want to double check i have the correct wires in the correct hole.
  2. RU55SSO
    RU55SSO Member
    792
    24
    Hey mate the connector for esp on mine is blue. and hazard is white. If your esp button is faulty i have one for sale. prefacelift version
  3. emeraldA3guy
    emeraldA3guy Member
    131
    OK looks like i made big mistake.
    I swapped pin 3 and 6 on accident. So I am wondering if my ABS module is bad now?
    Looks like 3 suppose to goto ground but it went to abs control module instead and 6 went to ground.
  4. emeraldA3guy
    emeraldA3guy Member
    131
    Thanks for the info but i guess i was not clear. I was looking for pin assignments on the ESP button but I got them.
  5. NHN
    29,577
    1,779
    Nah just get it round correct way & scan clear any errors, shouldnt cause a problem.
  6. emeraldA3guy
    emeraldA3guy Member
    131
    Thanks NHN!
    I'll scan it tonight
  7. Khufu
    Khufu Well-Known Member
    5,704
    31
    I think it should be ok too. A lot of modules are are switchable earths anyhow.
  8. emeraldA3guy
    emeraldA3guy Member
    131
    I forget to mention that I turned the car on and pressed the esp button and the esp dash light did not light up.
    I'll check the vagcom tonight
  9. Khufu
    5,704
    31
    You could also check the 5amp fuse SC4 in case you have blown it by earthing pin 4 straight to earth.
  10. emeraldA3guy
    emeraldA3guy Member
    131
    i checked the fuse last night and it was indeed still good.
