Afternoon all,
Wondering if anyone could shed some light on these codes and if it s safe to remove them.
I keep getting stop/start function unavailable, malfunction error come up on the dash.
Car is a 2010, 59 plate A4, 2.0TDi.
Address 01: Engine Labels: 03L-906-019-CAG.clb
Control Module Part Number: 03L 906 022 NN HW: 03L 906 019 AL
Component and/or Version: R4 2,0L EDC H22 9096
Software Coding: 12194012232503080000
Work Shop Code: WSC 00029 210 90976
ASAM Dataset: EV_ECM20TDI03L906022NN A02011 (AU48)
ROD: EV_ECM20TDI03L906019AL.rod
VCID: 7EF398DDE126E6B2BB-802A
2 Faults Found:
4922 - Implausible Data Received from Instrument Panel Control Module
U0423 00 [032] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
4096 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 00 [108] - Incorrect Correlation
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 254
Mileage: 158442 km
Date: 2016.08.30
Time: 17:31:02
Engine speed: 3950.00 /min
Normed load value: 84.7 %
Vehicle speed: 32 km/h
Coolant temperature: 80 °C
Intake air temperature: 39 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.280 V
Unlearning counter according OBD: 40
Engine start: start synchronization: EPM_MODE_OK
Epm st Sync: EPM_FULL_SYNC
Camshaft speed (RPM): 1868.5 /min
Epm Ca S phi Adap Ref Pos I1 mp 0: 129.20 °
Synchronous angle: -6.70 °
Epm Ca S phi Raw Value mp 0: 0.00 °
Epm H Cr S st Sig Mode: GAPFOUND
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8K0-907-379-V1.clb
Control Module Part Number: 8K0 907 379 BB HW: 8K0 907 379 BB
Component and/or Version: ESP8 front H04 0020
Software Coding: 160504
Work Shop Code: WSC 06335 000 00000
VCID: 7AFB94CDF50ECA9287-802E
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 3
Reset counter: 128
Mileage: 159652 km
Time Indication: 0
Date: 2016.11.05
Time: 16:40:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x40A2
Hex Value: 0x0032
Hex Value: 0x3394
Hex Value: 0x00FF
2 Faults Found:
U0423 00 [032] - -
Freeze Frame:
Fault Priority: 2
Mileage: 158442 km
Date: 2016.08.30
Time: 17:31:02
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 128
Mileage: 159652 km
Time Indication: 0
Date: 2016.11.05
Time: 16:40:57
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x40A2
Hex Value: 0x0032
Hex Value: 0x3394
Hex Value: 0x00FF
