Error code, HELP!!
amit91987 Jul 29, 2012
  1. amit91987
    amit91987 Member
    119
    Hi
    I have received the following error code:
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 BX HW: 8P0 920 981 BX
    Component: KOMBIINSTR. VDO H80 0460
    Revision: D08 Serial number: 2258GD08000039
    Coding: 0000443
    Shop #: WSC 12435 123 12345
    VCID: 8F294C689E46CD1
    1 Fault Found:
    16346 - Control Module - ROM Error
    014 - Defective
    Freeze Frame:
    Fault Status: 00000011
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 107136 km
    Time Indication: 0
    Date: 2012.07.01
    Time: 11:50:59
    Would anyone be able to advice me on what this is?
    Thank you
  2. mike foster
    3,967
    This is the nearest from Rosstech :- 16347 - Ross-Tech Wiki
    Presumably there is something wrong showing itself in the car ?
  3. amit91987
    amit91987 Member
    119
    Thanks Mike- the only thing that i have noticed is that sometimes in the dis, where the gears show- this randomly is blank when i switch the car on. I have to restart the car and the gears will show on the dis.
    I will try get a picture up to explain further.
  4. amit91987
    amit91987 Member
    119
    Here is a picture I got this morning
    As you can see, there is no display for my gears- I have a DSG.
  5. rokape
    rokape Member
    87
  6. mike foster
    3,967
    I'm afraid it looks like an intermittent fault in your instrument module. I'm not sure whether this can be fixed unless you buy a new module.
    Sorry, maybe somebody else will come along with some help
  7. amit91987
    amit91987 Member
    119
    Thanks Mike
