Error code 01139: with Eng Management Light ON HELP!!!!!!
jimbojet Apr 5, 2011
  1. jimbojet
    jimbojet Member
    61
    50
    Hi guys,
    I'm really scratching my head with this one!
    I have a VERY intermittant fault on my A4 2.0tdi (170) 2006. Sounds bizarre, but temps typically above 7-8 degrees and my Engine Management Light comes on. It will stay on for say 3 to 4 days then go off, then come on again at a later date, really driving me mad!!
    VAG-COM 311.2-N is throwing out the following:
    1 Fault Found:
    01139 - Central Locking Switch: Front Passenger Door Unlocking
    006 - Short to Plus
    When I clear the fault, the light goes out for maybe 24hrs then will re-appear.
    Why is the Central Locking causing my Eng Mangment Light to come on????
    What does the error code mean?
    What's the fix - if any???
    Many thanks guys, this is driving me MAD!!!!!!!
  2. hades-
    9,482
    646
    that fault wont make the light come on
  3. rowdyboy
    rowdyboy Member
    804
    19
    Where do you find the fault definitions starting with a 0? I stuck a mates cheap code reader on mine and it came up with a 0 code but all I can find on the internet is ones starting with "P".
