Erratic temp gauge...
Jp-tqs Nov 23, 2012
  1. Jp-tqs
    Jp-tqs Member
    183
    Hi all, got a problem......
    Temp gauge reads 90deg while driving, few mins later its bottomed out on 50deg, keep driving and its 90 again, then 50!!!!
    Temp keeps falling off, can anyone help me diagnose this please?!
  2. marktdisport
    marktdisport Active Member
    1,195
    15
    Get it scanned but I'd say coolant temp sensor is your fault
  3. I started with coolant temp sensor, doesnt seem to have fixed it, im going to change thermostat next,
  4. Jp-tqs
    Jp-tqs Member
    183
    Did scan it, came up with 18062 - check memory of innstrument cluster. ??? Im thinking cts but need some reasurance from people with similar faults!
    bit worried about my fault code, should i just clear it?
  5. marktdisport
    1,195
    15
    my reason for cts in this case is the erratic up/down is more electrical fault thermostats gentally open and close and slightly being stuck open stopping the gauge reading 90 this makes the gauge slowly to move 60/90 etc
  6. marktdisport
    1,195
    15
    yes clear the fault !! Then if it comes back fix it.....
  7. Jp-tqs
    Jp-tqs Member
    183
    Think (hope!) you might be right, car gets to operating temp on gauge but just falls off! So def electrical not mechanical. What else is in the system? Stat, cts.... Anything else?!
  8. yeah i understand your logic, i should of done stat first anyway as mine struggles to get to 90 always hovers between 60 and 90 and takes an age to get there, if id of used basic logic first id of sorted it first time :) suppose you live and learn though
  9. marktdisport
    1,195
    15
    Just these 2 items and both are very prown to failure, read so many threads about temp gauges in the last month it's untrue
  10. marktdisport
    1,195
    15
    yes m8 the one tell tail sign you've said above is it takes ages to get to 90 which suggests its slightly stuck open, a stat will sort you out bud
  11. Jp-tqs
    Jp-tqs Member
    183
    Can the gauge be faulty?
  12. marktdisport
    1,195
    15
    my opinion never say never......but IMO i wouldn't consider that yet
  13. Jp-tqs
    Jp-tqs Member
    183
    Can you get genuine coolant temp sensors online? Or is it a dealer trip?
  14. pauldazzle
    pauldazzle Well-Known Member
    1,192
    95
    I usually get all my VAG parts from TPS, always a bit cheaper than the dealer.
  15. marktdisport
    1,195
    15
    ive read a few horrow stories that people have changed cts and thermostat by cheaper versions and they still have faults after I would say buy at tps or stealers or of any vag specialist, I'd get both changed for piece of mind, the better it runs on 90 the better your mpg return will be
  16. Jp-tqs
    Jp-tqs Member
    183
    Been at work today so couldnt get to audi parts dept, do tps do online delivery? Want to get this sorted ready for a remap! Need it running right first though.
  17. Jp-tqs
    Jp-tqs Member
    183
    Am i right in thinking that cts is in the centre of this pic with the 2 wires on it? Just under the pipe with the vw/audi logo on it (rear of the cylinder head).
