Erratic Oil Pressure Gauge
Lemon S3 Apr 3, 2013
  1. Lemon S3
    Lemon S3 Alex
    1,390
    41
    Recently my oil pressure gauge has been acting a little odd. Here's a video of what it's doing
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Is that moving with throttle/rpm movement?
  3. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    how did you fit the oil pressure gauge?
  4. Paradox1
    1,833
    88
    Nah dan, I dont think it is rpm.
    I would check the wiring first. perhaps the pressure sensor has had it?
  5. Lemon S3
    Lemon S3 Alex
    1,390
    41
    No that's cruising, doesn't make a difference if I change the rpm.
  6. Lemon S3
    Lemon S3 Alex
    1,390
    41
    I made an adaptor that would take both the original sensor and the gauges sensor and would fit into the original sensor hole. I have just noticed a bit of oil around the sensors so there may be a small leak.
  7. Paradox1
    1,833
    88
    Yeha that could explain it, the pressure loss.
    Thanks, I got a guage and plan on fitting it this week maybe
  8. Tim_Attard
    Tim_Attard Active Member
    473
    44
    same issue here, did you manage to sort it?
