Erratic Idle
Olly P Mar 27, 2013
  1. Olly P
    Olly P My other cars a mk2 Golf GTi
    702
    13
    So, i've got an erratic idle on my 2005 A4 DTM. Fairly regularly, when I come to a stop the revs rise to around 1200 then lowly falls back to 800 ish.
    I've taken the car to a garage to fit coilovers recently and asked them to look at the problem They fixed a small boost leek and this cleared the engine management light.... after a day its now retuned.
    Is there anything I should check before taking it back? I don't have a copy of vag-com so can't scan for the code, i'm just wondering if any ones had similar problems? I've seen a few threads suggesting that it could be a faulty PCV valve?
    Any help much appreciated
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group s tronic S-line owners group
    3,988
    756
    I would look at the MAF, you could unplug it and see if the fault still occurs. Had this on a couple of my A4's and and it was the MAF. First one I was able to clean the other had to be replaced.
  3. Olly P
    702
    13
    Brilliant, thanks for the info :icon_thumright:
  4. claudefrog
    claudefrog Member
    372
    I heard the coolant temp sensor can also cause this issue, if you scan the car with vag-com or even a generic OBD reader it will help point you in the right direction.
  5. mancdan
    mancdan Active Member
    497
    51
