Erratic idle + fault code
Crunch Feb 15, 2009
  1. Crunch
    Crunch Member
    118
    Hi, Ive noticed that now and again my 2.0 tdi a3 will idle slightly erratically. Only really noticeable when sat at lights and the car will shake slightly. It only does it now and again.
    When I had it remapped, the bloke looked to see if it had thrown any codes, and it had thrown something to do with glow plug number 4 circuit failure, although this could have been an old code.
    Speaking to a friend, he seems to think the fault has nothing to do with the problem i've got and it's a possible sticking egr valve.
    Anyone got any ideas?
    Cheers, Dom
  2. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    won't be the glow plug error causing the problem as the glow plug only comes into action when the engine is started up cold
  3. RobinA3
    1,828
    47
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    I'd go with that too.
  5. Crunch
    Crunch Member
    118
    where would i start with that? cheers
  6. kaz219
    kaz219 Active Member
    1,808
    check the engine bay for hoses that have split/have holes etc.
    Also, check the seals..
    These can be identified as some holes may leave black marks around where the air has been escaping (the gungy black stuff thats found when the manfiold, imf, egr are stripped off..) This may only apply to the thick main pipe in the middle front of the engine where the egr is located...
    I have a pic of my air leak and how i identified it and a vid of the revs bouncing but this is on my home comp. Im at my flat at uni now..Probs wont be home till nextweekend or even the weekend after but when i get chance, i'll post the pic and vid and you can compare it to yours.
    My leak was inbetween the EGR and the manifold - the seal had perished as i changed the IMF and it must have moved about as they are connected...
    On Vagcom, the revs were idling between 810ish and just under 850ish IIRC. It happened when i drove the car for a few mins, parked it up and started it again... It was very slight but enough to annoy me!
  7. sprout99
    sprout99 Member
    373
    check the ones either side of intercooler.
    They are known for either popping out or splitting.
  8. Crunch
    Crunch Member
    118
    Thanks for the help. I'll have a look at the weekend in the daylight.
    Would i not notice the leak at higher revs, or wouldnt it make noise under boost?
  9. kaz219
    1,808
    It depends on the kidn of air leak.
    Mine was fine when driving - just idled a bit rough...
  10. kaz219
    1,808
    It depends on the severity of air leak and which pipe its leaking from...
  11. Lance-22
    Lance-22 A3TDI
    i sometimes get this problem but it is only very rarely, not enough to really bother me much but i will check for air leaks next time im under the bonnet as this seems the most likely cause..
  12. jemd3@yahoo.com
    jemd3@yahoo.com New Member
    Hi,
    Audi TDI 2.0 Sport 53 plate
    My car was just serviced and timing belt change by the main dealer. I now have, what sounds like the same problem. Did you get it resolved?
  13. sprout99
    sprout99 Member
    373
    our was cutting out when stood in traffic - new pipes fitted and idle speed turned up.
  14. APL TDi
    APL TDi Member
    289
    Mine ildes a bit rough every now and then.
    Its not enough to bother me though.
  15. Crunch
    Crunch Member
    118
    Not sorted it yet as i spent a few hours cleaning it today so cba working on it now. When yours does it does it do it enough to make the car noticable wobble and jiggle the passengers about. If you get out you can hear the engine, it almost sounds as if its misfiring.
    If it makes any difference my cambelt was done about 1k ago (not by audi)
  16. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    Strange, I just read this thread title as 'eric idle'..............
