EPC Light on, Loss of power !!!
Digger1 Mar 25, 2011
  1. Digger1
    Digger1 Member
    439
    OK as the title says EPC light coming on at over 2000RPM above 40MPH then total loss off power, like a dead spot, let the revs die down and the EPC light goes of till the rpm goes back up, Oh and it's fine on tick-over this only happens when driving ,,,, any ideas ??? :think:
  2. Dilligaf-UK
    Dilligaf-UK Chugging along VCDS Map User
    197
    I'd suggest getting it scanned with VCDS - we can then help further.
  3. Digger1
    Digger1 Member
    439
    Yeah I can get it scanned monday, Just wondered if anybody recognized the symptoms, as there's usually a mountain off knowledge on here !
  4. Dilligaf-UK
    197
    Probably all down the Pub
  5. Digger1
    Digger1 Member
    439
    LOL...
    Just unplugged the MAF sensor and it drove fine,all symptoms gone !!! tho the engine management light came-on so I'm thinking it must be that but would appreciate it if some-one with VAG-COM could confirm,,, I do have someone who can check it on monday but would like to sort the prob tomorrow if poss; I'm in Brum !!!
  6. Digger1
    Digger1 Member
    439
    OK managed to get it on VAG-COM today, Exhaust Sensor 1, is the only fault , I'm assuming that's the lambarda sensor, if there's still anybody using this site
    with any knowledge please let me now...
  7. Digger1
    Digger1 Member
    439
    Tried the exhaust sensor, still the same,put back on vag-com; fault 17428 fuel pressure regulation control range exceeded,,,, any ideas ????????????????????????????
    And today it was fine until it got warm after a 15 mile drive,,, and only happened at about 60mph and above, could it be a fuel filter or pump struggling to get the fuel through when labouring at at speed ???????????
  8. baynesey
    baynesey well you better unsell them, sharpish!
    194
    Mine has started doing exactly this, I'm well over due a fuel filter, it feels as though it's starved of fuel
  9. Malko
    Malko Member
    41
    Sounds like it could be the crank sensor or fuel lift pump. Your explanation of it feeling like its struggling with fuel would make me sway toward the lift pump? but only a suggestion.
    Hope this helps!
  10. Malko
    Malko Member
    41
    Oh, forgot to mention, a lot of the sensors on the A4 don't register until the car is over 2000 rpm or so, so this would explain why/when the light comes on and is fine when idling. I can't really remember the reason for this but its something to do with stopping the car cutting out when idling.
