EPC check engine light
honda ctr Feb 9, 2018
  1. honda ctr
    honda ctr Active Member
    220
    55
    When ignition is on EPC light and check engine light is on. when engine started they turn off. is this normal?
  2. Svenedin
    Svenedin Well-Known Member Team Navarra Audi S3 quattro s tronic
    305
    315
    If you turn the ignition on and wait (before starting the engine) do the lights go off?
  3. honda ctr
    220
    55
    No they don't
  4. Svenedin
    305
    315
    I think you are OK if they all go out when the engine is started. All the warning lights come on when the ignition is switched on so that you could tell if a bulb had blown (if the bulb for engine warning had blown for example you would never know if it was actually trying to show you a fault unless you noticed it didn't light up when the ignition is switched on. With my car the warning lights come on but then switch off but it has virtual cockpit.
  5. honda ctr
    220
    55
    I've looked on YouTube they all gone on but go out. My EPC and check engine only go out when I start the engine.
  6. SamR92
    SamR92 Active Member Team Floret Silver Audi A3
    292
    219
    43
    As long as they go off when the engine is started its normal
    4K likes this.
  7. honda ctr
    220
    55
    Strange I never picked up on it before but clips on YouTube they come on with ignition on and off with ignition on. Mine go out with engine started.
  8. MikeParkin
    MikeParkin Well-Known Member Team Ibis Audi S3 Manual
    979
    812
    93
    If there off once the engine is started and there not displayed whilst the car is running etc then all is well.
    I had a boost issue and when the problem arised EPC light came on and stayed on until the engine was re-started. It continued until I sorted the problem.
