Engine's transfer
renton May 26, 2013
  1. renton
    renton Member
    64
    Hi all I have a A3 1.8t agu engine for sale and a friend has asked if it will go in a A4 1.8t as his has snapped the belt. So he would like to put the block and head in and use his turbo and manifolds will this work.
    Thanks all
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    Yup all exchangeable. There are differences with the cam cover which is worth noting when doing the swap.
  3. Broken Byzan
    13,237
    465
    Nope, won't go. 058 and 06a different enginers, mounts won't swap over, different flywheels and clutches
  4. Jay 01 s3
    Jay 01 s3 Member
    136
    10
    Yes it will, a buddy done same conversion it was a 06 a4
  5. 16Klappe
    5,795
    1,186
    How certain of that are you?
    Why won't the mounts swap over? Friend of mine used a Passat engine in his Mk2 Scirocco, I was sure the blocks were the same.
  6. <tuffty/>
    21,374
    3,937
    the 058 block used in the A4 is derived from early VAG 2ltrs (ABF etc) you pillock lol... fancy asking if Marks is sure... LMAO!!!... he has forgotten more about A4's than you actually know... ;P
    Transverse is 06A block, inline is 058... do some research...
  7. Broken Byzan
    13,237
    465
    Really you want to get into this?
    The later a4 is based upon an 06b unit which shares the same mounts but is alloy block.
    058 block is external waterpump and almost identical to the KR/ABA style block and as such will drop in on the same mounts but you have to use the flywheel and clutch from the donor. If the 06a unit is used then you need to use mounts from an ibiza to make it fit. I would get technical and produce pictures but can't be bothered.
    Sell it to your mate, Jardo says it will fit, I'm sure he knows best....
  8. 16Klappe
    5,795
    1,186
    So they do fit then with the right mounts?
  9. Prawn
    11,538
    3,493
    Robin bought an 058 block because he couldn't find a decent priced 06A.
    As it happens, it's bloody lucky he did, because the mounts are totally different, and the 058 went straight in using OE mounts on the engine side.
    Had he followed the plan and bought an 06A he'd have had a whole load more work and had to make up mounts.
    So yea, they're pretty different.
  10. 16Klappe
    5,795
    1,186
    But in short...they do fit.
  11. Prawn
    11,538
    3,493
    NO!!!! FFS dude. let it go.
    Sam_ and m19lte like this.
  12. Broken Byzan
    13,237
    465
    in the boot yeah. Not under the bonnet and connected to the chassis with bespoke work to get it into the A4.
    As stated the A4 one will go into the rocco as will the 06a with the right mounts, there is no such thing as the correct mounts to fit the 06a into a b5. If you use B6 mounts you are opening another actual can or worms, all this for a cheap engine, AEBs are like £200 complete nowadays.
  13. 16Klappe
    5,795
    1,186
    [Rant]Nope, I refuse now. Mark and PT are having a huge case of unnecessary PMT, as are you actually.
    A simple explanation could have done, but nope...that's not the ASN way. People are allowed to run around asking the same freaking questions every single day, but Jardo doesn't understand why a bit of hard work and adaptions mean something can't be done and BOOOOOOOM like a ton of bricks.
    #nottheonlypersonwhosaysorthinksitcanbedonesowhynotasktheguyabovewhoclaimstohavedoneitratherthanbeingarseyaboutit
    *awaits being removed from discussion*
    Xxx[/Rant]
    Cheers for the explanation Mark. NOW I understand.
  14. s33nyboy12
    s33nyboy12 Well-Known Member Team Ibis Team V8 Audi R8 s tronic
    1,488
    203
    Lol lol lol now that's entertaining! :)
  15. 16Klappe
    5,795
    1,186
    Indeed, entertainment is my middle name.
  16. Broken Byzan
    13,237
    465
    Not the word running thru my mind..... :whistle2:
    :beerchug:
  17. Prawn
    11,538
    3,493
    Really?
    So the second post wasn't simple enough for you?
    Quit your whining.
  18. 16Klappe
    5,795
    1,186
    It's you doing the whining.
    Don't think that just because you're power to weight is up I won't kick your ass. I'm a black belt, this one gang wanted me to join because I've got skills with a bow staff.
