Engine wiring geek needed... cant find where this one cable goes! =/
rob_sri Dec 31, 2010
  1. rob_sri
    rob_sri If in doubt, flat out
    112
    right blanked off my air thingymabob.. that black mini dustbin under the airbox :p
    cant remember the name of it.. minds gone blank!
    EDIT: secondary air injection.. :)
    ANYWAY.. there are a few cables hanging about from when my new engine has been fitted... cant find a plug for them!
    on the same harness as that air thing (square connector with a metal clip).. there is the bonnet catch senor which i connected up and something else.. thick two pin plug with two thick wires into the block with thick black conduit around it..
    does anyone have a picture/wiring diagram??
    long shot but i searched for a good long while earlier!! :wacko:
  2. hades-
    hades- Yorkshire & Humber Rep. Regional Rep VCDS Map User
    9,480
    646
    pictures may help
  3. NHN
    29,284
    1,695
    Wire colours would help us tbh as can check elsawin then aswell.
  4. rob_sri
    112
    They are yellow with red stripe and a brown pics to follow
  5. rob_sri
    112
  6. rob_sri
    112
    the one im holding is the one in question :) i think the other is for the secondary air thingymabob
  7. NHN
    29,284
    1,695
    Thats a meaty bastard aswell so must be for something that needs a fair bit of current, fan or something, can you tell me these things:
    1. Whats the black housing part number on each connector shown, should be 10-11 alphanumeric digits
    2. What year is the original engine from
    3. What was the original engine & box codes
    4. What colour wires are the other connectors
  8. rob_sri
    112
    1. 1j0 973 732
    2&3. 99 APY not too sure about the box.. whatever came standard on the S3
    4. the other one in the pic with the metal clasp is green with a yellow stripe and brown with a yellow stripe
    Cheers dude :)
    this is doing my swede in! cant find a home for it anywhere!
  9. Westy
    Westy Well-Known Member
    17,440
    1,096
    Is that not the plug that goes on the knock/timing sensor? The one on the front of the manifold area left of the oil dip stick?
  10. beachbuggy
    beachbuggy Well-Known Member
    1,931
    199
    That is for the SAI. You can leave, but it will give error codes on vagcom or you can fit a resistor across the terminals, can't remember the value but it can be got from maplins though. I'll have a look to see if I can find the info. I do know there was a guy on edition38 selling a custom plug with resistor for about £8.
  11. beachbuggy
    1,931
    199
    10w 330omhs.
  12. NHN
    29,284
    1,695
    99 apy SAP has a white wire with red stripe & brown, you sure its yellow & not discoloured white?
    That connector isnt showing for 99 apy or 8L in general in etka, but etka has been known to be wrong & given age of apy it could just not be listed, whats the smaller wire connector part number & recheck large one aswell please.
