engine weight
teo420 Jun 19, 2011
  1. teo420
    teo420 Member
    49
  2. Broken Byzan
    13,244
    468
    Thats cheap, iirc it will be a pallet collection you need, will cost you around £75-£90 up to half a tonne or something, basic block has to be in the region of 120 kg ish
  3. teo420
    teo420 Member
    49
    yea price is not bad
    now I have to look into rebuilding my turbo
    where would I be able to find parts for it ?
    or if anyone has a turbo for about 100 i might consider it ;)
  4. Bradderz_1988
    3,995
    262
    I will have one but it won't be till middle of next month as the Frankenturbo is getting ordered on the 28th but don't no what the delivery time is and then a date to fit it, can't wait :) also the hot side (turbine housing) needs replacing as the wastegate penny valve is ready for falling off.
  5. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,913
    166
    Rebuilding a turbo is a pecision and expensive process... the shaft has to be balanced for one. But if its run devoid of oil, the turbo will probably be little use as an oily paperweight. The one bradderz has would do you, then you just take the hotside off yours and swap them.
    but i'll PM you later on, may know where there is one cheap.
  6. AR-rkon
    1,913
    166
