Engine transplant. Advice needed
shaz-raul Sep 24, 2009
  1. shaz-raul
    shaz-raul Member
    87
    hey guys
    hope you're all well.....
    my oil pump on my a4 1.8t sline 190bhp decided to pack up on
    me recently an ruined the engine.
    i have been looking for the same engine code an it is becomin near enough impossible to find a BEX.
    i have found one with 34k on the clock but they want £2300 supply n fitted.
    a friend of a friend recently wrote off his 58TT and has a 2litre tfsi with the ecu n loom..... i wanted to know is it possible for the engine to be fitted into my car? are there any complications that i could possibly face.
    any advise an also if you guys know anyone highly recommeded to fit the tt engine into my a4 within london would be much appreciated.
    thanks in advance guys
  2. quattrojames
    14,050
    578
    What warranty on the £2300 one? I would push for two years and 20k miles and go with that if I was you, thats not a bad price is it?
    I take it thats just an exchange using your existing ancillaries?
  3. J7USS
    J7USS Shuddup Foooool!!
    3,737
    77
    Is yours a Quattro??????
    Is the TT a Quattro????
    Ive heard that to fit a TT engine you would need the Gearbox too as it aint compatible with your BEX fitment - Im not 100% on that though so deeper investigating will shed some light!
    As for the £2300 fitted - as james said, what exactly is that for???? are they using your old engine as a doner too???
  4. shaz-raul
    shaz-raul Member
    87
    my a4 is front wheel drive i didnt even ask to find out if it was a quattro engine. this sounds like a long job already!
    the £2300 is for a 1.8t complete engine fitted which has covered 35k. they didnt say they wanted the engine as a donor.
    http://www.car-partsonline.com/
    they are the people i called for the engine
    there is another place i found on ebay which is selling a bex reconditioned engine for £1150 but they want my current engine is return an i need to get it fitted
  5. docurley
    4,071
    86
  6. shaz-raul
    shaz-raul Member
    87
    thanks docurley... jus a quick question for u... the engine that u have put up the link for is a quattro, my car is a front wheel drive.... wud it fit?
  7. docurley
    4,071
    86
    It does not matter at all as you will be using your gearbox the engine side is just a 1.8T like all the other with little changes here and there.
    Most your guy may have to do is swap a few sensors over.
  8. docurley
    4,071
    86
    If you do go with the AJL engine do a cam belt change with new water pump and drop in a new oil pump and oil pickup pipe.
  9. J7USS
    3,737
    77
    There you go, confirmation on that issue, all sorted then, get it bought and Listen to the Doc mate as he knows alot more about engines than most of us on here. He's advised you well on the Oil pump side of things aswell!! Id rewrite the Bible to include that if I could!!:laugh:
  10. shaz-raul
    shaz-raul Member
    87
    cheers guys
    doc do ya know any reliable mechanics around east london or jus over the river?
    worth droppin in anythin bigger? or too much hassle for wat its worth?
  11. J7USS
    3,737
    77
    B5 Rs4 Engine or the B5 S4!!:rockwoot:
  12. shaz-raul
    shaz-raul Member
    87
    j7usss dude im a poor man why u temptin me to rob a bank for an rs engine! :hubbahubba:
  13. howdy quattro
    howdy quattro Member
    320
    your just the latest in a long line of forum users mate, he's abit of a slag when it comes to tempting us all to part with our hard earned cash!!!
  14. J7USS
    3,737
    77
  15. quattrojames
    14,050
    578
    :drag:
  16. aragorn
    18,490
    855
    Be reet ;)
    As said, find an AJL or tbh any 1.8T. They're all very similar motors, and even if you baught a 150hp model all you'd need to do is swap the turbo and inlet manifolds from your original engine onto the replacement, and continue using the BEX ECU.
    Having said that, the BEX probably has variable valve timing, and the AJL probably does not. Im not sure if this means the BEX ECU will take the huff, or if you can swap the VVT parts onto the AJL, but it might be an idea to try and find a VVT engine for the swap if thats the case.
  17. J7USS
    3,737
    77
    ..obviously I was Joking when I said the Rs4/S4 engine BUT theres no harm in Wishing!!
  18. docurley
    4,071
    86
    VW Enterprise on the Walworth Rd, his name is Darren and he will be more than able to do the conversion tell him David with the Audi A4 sent you.
    Tel:+44 (0) 20 7703 8689
    http://www.vwenterprise.co.uk/services.php
