Engine Ticking Noise
Sm[]key Apr 3, 2007
  1. Sm[]key
    Sm[]key New Member
    19
    My Audi A4 1.9 Tdi 1998 has developed a ticking noise which sounds like the timing is out.
    I have ran the vag-com tdi timing checker and it indicates my timing is slighty advanced but within the ok region.
    Any idea what could be up with the car as I'm not to clued up when it comes to diesel engines.......I've only recently noticed the ticking, so this could have been happening for a while.....
  2. golisago
    golisago Member
    Where does the ticking seam to be coming from , have you just had it chipped or perhaps a tuning box has been added.
  3. Sm[]key
    Sm[]key New Member
    19
    It sounds like the tappets as on a petrol engine. I am assuming its the same problem.
    No there have been no performance mods that I am aware of.
    I think I'm gonna have to strip the lot this friday, so I was wanting ahead start if anyone had an info for me.....
  4. Sm[]key
    Sm[]key New Member
    19
    I've had a mechanic friend have a listen to the noise and he says its one tappet making the noise.
    Has anyone stripped the cam out to replace along with all the kit (followers/guides/etc.)?
  5. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Try changing the oil first, drain out the old oil, fill with flushing oil and run for 10 mins at fast idle, drain then refill with new oil and see if that helps.
    Bit quicker and cheaper than stripping the head.
