Engine temperature
jamie226bhp Jan 8, 2011
  1. jamie226bhp
    jamie226bhp Member
    468
    Just been out and car got to 90 on the gauge then I noticed it start to drop til it got to 60 stat and temp sender only a few months old, would I be correct in thinking the viscous fan is sticking on
  2. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Viscous fan runs all the time anyway. Does sound like the thermostat is stuck open.
  3. AudiiduA
    AudiiduA Member
    359
    Take it on a good run and see what happens? i know from experiance if your car has a very good cooling system with a viscus fan it sometimes needs a good run too operate stat properly!
  4. jamie226bhp
    jamie226bhp Member
    468
    Will see if a long run makes any difference, although it did get unto temp but as soon as the fan kicked in it dropped all the way down and the fan didn't seem to switch off and both the stat and sender are only two months old
  5. jamie226bhp
    jamie226bhp Member
    468
    Wonder if the fan switch is faulty, got to be a cheap thing to try
  6. PaulTheo
    PaulTheo Member
    126
    Check the sender and stat the fan could run all day and not effect the temp if the stat is OK.
  7. THE MONSTER
    THE MONSTER Member
    231
    Have you tried Bleeding the system probably air in from when you changed the Stat can be hard to get out sometimes..
    I have had same problem before after changing Stat..
  8. aragorn
    18,306
    806
    It will be the stat.
    Even if theres a force 10 gale blowing thru the radiator it shouldnt matter, if the stat is working it will just close down the flow thru the radiator to control the temperature.
  9. jamie226bhp
    jamie226bhp Member
    468
    Stat is new though, well two months are they prone to going wrong even when only this old
  10. aragorn
    18,306
    806
    Was it a decent one and was the sensor genuine?
  11. PaulTheo
    PaulTheo Member
    126
    I changed one on a B5 and it made no difference so looked at everything again! Then fitted some temperature data recorders from work and they confirmed the temp dropped off the faster I drove. I then fitted an original Audi thermostat and perfect bang on 90 degrees all day long.
  12. jamie226bhp
    jamie226bhp Member
    468
    Got from gsf but the sender was the green one and the stat was the better quality one
  13. ian52
    1,199
    Maybe just a bad one. Mine was like this then i changed the stat and it never moves off 90 deg when warm now.
  14. Foxmeister
    Foxmeister Fired Up!
    1,785
    Cheap stats known to be faulty straight after fitting!!!!
    Depends how better quality yours is? Even then still points to that.
    You can do a quick hot water test on the stat to check it opens/closes fully.
  15. jamie226bhp
    jamie226bhp Member
    468
    Must be that then, anyone know the price of a genuine one
  16. sprint_48
    sprint_48 Member
    52
    Have a similar problem. My car almost always sits at 60 no matter how much I drive it. Sometimes gets to about 70, but rarely. Looks like a new thermostat needed then
  17. jamie226bhp
    jamie226bhp Member
    468
    Mine wasn't even that cheap think it was £23 and lasts 2 months,
  18. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Think mine was around a tenner. There not expensive.
  19. aragorn
    18,306
    806
    Genuine Stat is about 20quid, Genuine sensor is around 35.
