engine temp display
yendall24 May 23, 2009
  1. yendall24
    yendall24 Member
    571
    hi all does anybody know the procedure to display the engine temp on the climate control display i think i have a dodgy temp gauge as the engine oil temp gauge starts to rise 2 to 3 miles before the water temp gauge begins to move all the other audis i have owned its always been the water temp that starts rising first any info would be welcome
  2. GSB1
    GSB1 Member
    283
    Can't remember the sequence (not without doing it anyway) but code 49 gives me accurate coolant temps. It may differ on year, but on my '98 pre-facelift that works.
  3. aragorn
    18,373
    829
    does it ever reach 90?
    The coolant temp should come up to 90 pretty quickly and sit there unmoving. If it slowly comes up and never reaches 90 then it may well be the thermostat.
  4. GSB1
    GSB1 Member
    283
    Worth checking with the climate and VAGCOM if you can too. Although vagcom wil give you the true reading ntot the massaged guage reading.
    Worth changing the coolant temp sensor just in case before you get to the conclusion of thermostat.
  5. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    mine was like this. it would hardly move in winter so i changed the stat and it sits bang on 90 all the time.
  6. Broken Byzan
    13,237
    465
    recirc and the manual up arrow IIRC
    Then as stated psotion 49 i think
