Engine taking ages to warm up?
Jaywoo_A3 Dec 19, 2007
  1. Jaywoo_A3
    Jaywoo_A3 Member Audi A4 Audi Avant Owner Group S-line owners group
    542
    I noticed on the way home from work yesterday and coming to work this morning my car took ages to warm up? by the time i get to work it normally up to full operating temp (90'C on the gauge) but this morning it only reached 65'C.
    I took it for a drive last night and it eventually got up to temp but took much longer than normal?
    What are the possible causes for this? Jammed open thermostat?
  2. Clach
    Clach A3 - 1.8Ts
    971
    Did you have the heater on this morning...That sucks the heat right out of the engine. I would say, given these cold mornings, and taking into consideration when you last used the car) by 10 miles or so it should be at the right temp.
  3. mattm
    mattm BLACK EDITION
    184
    Yeah I have this also, put the heater on full blast on hot so as above it sucks all the heat from the engine - making it even longer to reach temp. Due to the cold weather!!
  4. Jaywoo_A3
    542
    Yes the heater was on low but its no differnt to every other morning, It is 10 miles to my work so should be up to temp by the time i get there.
  5. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Faulty temp sender or thermostat stuck open. My A4 reaches 90 just on the school run which is only 3 miles, but I always turn the climate control off until I have some heat registering on the guage.
    Once it hits 90 does it stay there? If you whack down the motorway does the temp drop off?
  6. SteveU
    SteveU New Member
    Sounds like a stuck open thermostat to me. Mine's exactly the same. Not looking forward to changing it though as it's behind the timing belt on the 2.6.
  7. Jaywoo_A3
    542
    Mine is a pretty easy job to change so ill get one and try it,
    Thanks AndyMac and SteveU, just wanted to hear everyone else thought before i change it?
  8. Felon
    Felon Slightly odd.
    87
    Also see the spluttering and dieing thread above...
  9. AndyMac
    9,832
    46
    If the thermostat is stuck open then the temp should drop off when cruising on the motorway as the coolant will be getting too cold from the additional airflow through the rad. If this isn't the case then I'd change the temp sender first as it's an easy job and cheap too at £20.
  10. sitrials
    sitrials Member
    872
    i'm the same i do 20miles to work mines all motorway a barely reaches 75 on the guage, with no heating on but in traffic climbs no problem.
  11. Prawn
    11,639
    3,628
    Mines exactly the same. IN traffic it will reach 90 fairly fast and stay there, yet down the A3 40 miles every day it barely gets over 65-70 these days.
    I know its the stat though, I just need to change it.
    Ive got a new stat, but I really cant see how people change it so easily! I couldnt find a tool in my kit to reach the lower bolt.
  12. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    THERMOSTAT 110% Get it changed DIY £25
  13. sitrials
    sitrials Member
    872
    prawn i have ELSA that might help you!
  14. Jaywoo_A3
    542
    Thanks guys, went and got a stat last night and going to change it at the weekend, Will let you know if this cures it?
  15. sitrials
    sitrials Member
    872
    changed mine yesterday as everyone was so sure i tested them both in boiling water new and old my old one opened within 20secs where as the new took a couple of mins.
    warms up alot quicker now and sits at around 80-90c.
    cheers
    guys wasn't too bad a job either. thanks to ELSA.
  16. Jaywoo_A3
    542
    Did mine on saturday, Mines getting warmer a lot quicker too, :)
