engine swap amk to bam engine, s3 8l
m19lte Apr 13, 2013
  1. m19lte
    m19lte Member
    123
    Morning all
    Im in the process of swapping my 2002 amk S3 engine which has snapped a rod and put a hole in the block. (vvt wideband engine so im told ?)
    What I need to know is will a late 06 I think low mileage bam leon c r complete engine Plumb straight in and work off my original amk ecu ? Ecu has a cus code stage1 map.
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Yes it should be the same, what i would do if it was me, is use the bare BAM engine but bolt all your sensors and manifolds to it, that way if they changed anything over the years it wont mess you about
  3. m19lte
    m19lte Member
    123
    Yea I'll swap the sensors over as I know mine worked, just not 100% on the ecu and running side of things
