Engine Start Button Upgrade
S6 LeMans Aug 31, 2009
  1. S6 LeMans
    S6 LeMans S6 LeMans Man
    27
    Has anyone got any idea if it would be possible to change the old square plastic button to the new 09 model Chrome version?
    As you can see from the pictures below - the original housing/surround is still the same in the new 09 model year centre section. So I guess all that would be required from a dealer is a new housing and button - plus whatever time is involved in removing/accessing the console.
    Current version
    New version [ left hand drive though ] + CHROME ENGINE START
    Close up of button and its housing/surround
    I also like the neat chrome touch to the park brake.
    If you can easily change the panel = great
    I'm in at the dealers tomorrow - i will ask and report back
  2. Cockney Boy
    Cockney Boy Member
    483
    I would say it would be fairly easy to do, as the footprint is the same, however, it is just a button or is there some logic involved. You may want to ask a8tech (forum member) the question.
  3. elan2s
    elan2s Active Member
    343
    40
  4. S6 LeMans
    27
    Dropped my car in for some work today at the dealers - I had emailed them this question & they think its as easy as swapping it over?? The part is £30 - but is on back order. But to make doublely sure - they are checking if theres no other software change required??
    I have told them once that's established - then order me one ASAP :icon_thumright:
    They did say that when the change took place on the A8 - that was no problem - but the A6 they have no experience as yet.
  5. S6 LeMans
    27
    Thanks for the link - it confirms can be done :icon_thumright:
    But for those wanting to know imm. Here is how
    Audi A6 C6 Engine start/stop button removal and installation:
    Materials: Plastic spatula (anything that will not scratch), paper towel
    Remove the leather boot around the gear selector using the spatula wrapped in the paper towel (to avoid scratching). There are four tabs, as shown below. Start by inserting the spatula on the passenger side of the boot.
    With the boot out of the way, remove the gear selection indicator by applying upward pressure from underneath
    Now the start/stop button can be removed by using your fingers to push it up and out.
    8 pin--direct replacement
    After [​IMG]
    Its a nice easy mod for something you will see every time you get in. There is a similarly facelifted parking brake switch available.
    :hubbahubba:
  6. Cockney Boy
    Cockney Boy Member
    483
    That looks very easy.
  7. S6 LeMans
    27
    It's even easier than that........... I managed to pull/lift out the entire housing for the stop/start buttons just by using my fingernails - its that easy - they are not held in tightly at all - there is just a small spring bar retainer clip at each end.
  8. Cockney Boy
    Cockney Boy Member
    483
    Yo must have fingernails like a Gorilla, there is no way im chipping my nail polish to do that mod LOL
  9. S6 LeMans
    27
    It was even easier than previously described:-
    Fitted the new push-button switch in less than a minute last night.
    Simply use a credit card edge [ or similar ] to slot into the gap/surround of the original switch to assist in uplifting the switch assembly proud of the console. . . . . . then easily pulled proud with enough spare cable behind it. The switch is connected with a simple to remove/replace single cable.
    Attatch the new switch - replace in console = Job Done
    Total cost = £34
  10. Cockney Boy
    Cockney Boy Member
    483
    Like Paul Whitehouse says in the Aviva ad, "Bargin"
  11. Golfather
    Golfather Member
    75
    All you need to do now is upgrade your steering wheel and your dash trim ;)
  12. gravissima
    gravissima New Member
    Hi! i am trying to do this but my dealer has got the wrong switch.
    Does anyone have the RHD UK part number, i have only found a US lHD one?
  13. gravissima
    I found it and thought I would post it for info.
    It is 4F2 905 217E VUV.
    It cost £38 inc the VAT and easy to fit.
    I used a small watch screwdriver inserted into the switch (ignition key left in the house just in case) and it just opped out with just gentle pressure. Looks great!
