Engine Start Blocked by Immobilizer .. Huh?
a6_chris Jul 2, 2013
  1. a6_chris
    a6_chris Well-Known Member
    1,883
    160
  2. BradV6
    BradV6 Member
    84
    my mk4 golf once done the exact same thing, glow plug light flashed and wouldn't start, not even cranking. I was stuck at work so I kept trying and eventually it worked like normal, never fixed it as it only done it once and never again, though i did swap the key for the spare!
  3. hades-
    9,481
    646
    fault from transponder to car
    nothing to do with battery in key
    prob just gremlins
  4. a6_chris
    1,883
    160
  5. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Are you local? i could check your transponders are sending and recieving signal. more likely a sticky relay or switch unless the cluster is on its way out.
  6. a6_chris
    1,883
    160
